Brush Cutter
   / Brush Cutter #1
ColdBlackWind
Trigonia, Tn.
Farmtrac 60
I have a CT322 Deere. It doesn’t have an enclosed cab. Wanting to get a brush cutter to take care of the wooded area of my property. Was thinking about using expanded mesh with 1/8” lexan for a front shield while using the brush cutter. Thoughts??
   / Brush Cutter #2
Old conveyor belt cut to fit and chains have worked for most people for years, I would think that expanded metal would be hard to clean up once clogged up with grass clippings .
   / Brush Cutter #3
Are you putting the shield on the cutter front or behind the tractor seat?
Bruce
   / Brush Cutter #4
Bruce
I made the assumption that he was talking about building a guard for the front of the cutter, but you know what assumptions are good for doing.
   / Brush Cutter #5
A JD CT322 is a skidsteer. So I imagine he will put the guard in from of him.
   / Brush Cutter #6
Google seems to think that Deere is a track loader?
   / Brush Cutter #7
1/8 polycarbonate isn't that thick. I've seen a rotary cutter on a tractor sling a grapefruit sized rock in a split second. What thickness are they using on the OEM shields?
   / Brush Cutter #8
I've used a skid steer cutter many a day with no front glass. Just keep it tilted up if you lift it high. I've cleaned some nasty places with it. I never have it to where I can see the blades.
   / Brush Cutter #9
There are aftermarket skid steer doors available and there’s aftermarket metal door shields if you want something more durable.
   / Brush Cutter
The machine is a track loader and I would be mounting on the front of the cab like a door. I don’t really care for the aftermarket enclosures and one from JD is stupid expensive. Was thinking expanded metal to get some air. A metal door shield sounds interesting. I had not run across that.
2000 PETERBILT 357 6X6 DAY CAB ROAD TRACTOR (A51406)
2000 PETERBILT 357...
NEW 2024 LOAD TRAIL 83IN X 14FT Tandem Axle Dump Low-pro Trailer (A51039)
NEW 2024 LOAD...
2018 John Deere 460E Articulated Dump Truck (A51039)
2018 John Deere...
2022 Case TR340B Skidloader (RIDE AND DRIVE) (A50774)
2022 Case TR340B...
2022 John Deere S780 Combine (A50657)
2022 John Deere...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51222)
2018 FREIGHTLINER...
