Brush hog driveshaft snapped in 1/2!
   / Brush hog driveshaft snapped in 1/2! #1
denverdave66
Missouri
2012 John Deere 1016, FEL, 60"MMM
I just got my LandPride RCR1248 on Friday and just now got a chance to use it, hooked it up and drove it about 20 feet and the darn driveshaft snapped in 1/2! What in the world caused that! I was running it on my 2012 John Deere 1026.
here is a picture
   / Brush hog driveshaft snapped in 1/2! #3
Drive shaft has 2 parts that overlap. Your drive shaft may have been cut too short not allowing enough overlap when the rear of the mower deck is in a lower position and thus the 2 drive shaft parts would pull apart from each other. Check with you dealer if they had cut (shortened) the driveshaft.
   / Brush hog driveshaft snapped in 1/2! #5
Agree, was too short. One of those two pieces slide into the other. Not broken.
You are in luck, and only need to get the right length shaft. :thumbsup:
   / Brush hog driveshaft snapped in 1/2! #6
I'll fourth that. Good thing it didn't fly up and hit someone
   / Brush hog driveshaft snapped in 1/2! #7
I concur too. My bushhog tiller pto shaft is the same way. I have a question - do you have a quick attach mounted? this will lengthen the pto shaft distance. I'd remove the quick attach if you have one.
When putting the pto shaft together - note there is a flat spot on one of the corners that only mates on one of corners to other shaft. Don't ask how I know :laughing:.
   / Brush hog driveshaft snapped in 1/2! #8
Did you have the tractor end of the shaft securely latched in place to the rear PTO shaft? Perhaps it just came off the PTO shaft and then slid apart. Might not be too short after all.
   / Brush hog driveshaft snapped in 1/2! #9
IN other words, it appears nothing is broken. The PTO shaft is designed
to be "Telescoping". Pick it up, wipe off all dirt and you will see the
male end fits into the female end. perhaps you were sold a too short
of shaft OR, MAYBE, if you did not have the shaft fully connected
to the tractors PTO Stub, maybe it simple fell off!
You probably have an end w/ a spring loaded retainer, did you pull
back and seat the internal setting ball bearings when you connected
it up?
If still stumped post up my pics of the endsa dn everything involved.
   / Brush hog driveshaft snapped in 1/2! #10
I agree with everyone - the staft is too short - other than that nothing is wrong. i learned that the shaft slide into each other when I unhooked my attachment and forgot to unhook the pto and drove off sliding the shaft appart...i looked back and thought....oh ##@#!!!
   / Brush hog driveshaft snapped in 1/2! #11
I see you list i Match Quick Hitch. This adds to your draft arms length, so PTO shaft needs to be longer.
Put it back together and mark the safety shield with the cutter on the ground (should be the longest position of the PTO shaft). Then take the PTO shaft off and determine how much overlap you have. You need at least 6"
Did you buy used? Former owner may have cut the PTO shaft too short. Or new? Did seller set it up? Does the owners manual address the PTO shaft set up? My Bush Hog manual does.
   / Brush hog driveshaft snapped in 1/2! #13
You Possiably could make up the distance with a safety clutch..That would take up the distance, if clutch will fit? Buying another shaft would probably cost less..so..
   / Brush hog driveshaft snapped in 1/2! #14
Might already have the clutch in the shaft. Or is it shear pins?
   / Brush hog driveshaft snapped in 1/2! #15
Besides, I think most if not all have a clutch affair to keep the shaft from being damaged when it hits anything. As they said above your shaft pulled out from being over extended. Just slide the smaller back into the bigger.
   / Brush hog driveshaft snapped in 1/2! #16
And wait for it to happen again?
   / Brush hog driveshaft snapped in 1/2! #17
I have a feeling the shaft length did not take into account the extra length necessary when using a quick hitch. Might be able to just add a PTO extender to the tractor's PTO shaft.
   / Brush hog driveshaft snapped in 1/2! #18
Exactly!!! Thanks for saying it...My shaft only has 4 inches make up on the tiller..probably a lot less torque than a bush-beater? It does use a shear bolt for protection...If i torque mine out, or twist-it, i will Buy a longer shaft..I haven't sheared a bolt in my first years uses..But did look into buying the clutch, it was $120.00 at TSC..it looked to add about 3 inches more??l
Well I think it is the shear bolt that holds it on to the gearbox, one guy said it is an easy fix if I can get my hands inside the plastic bell.
2449 (A60432)
2449 (A60432)
2019 CATERPILLAR 304E2 CR EXCAVATOR (A60429)
2019 CATERPILLAR...
2021 CATERPILLAR 308CR EXCAVATOR (A60429)
2021 CATERPILLAR...
2007 Ingersoll Rand G240 240kVA 3-Phase Towable Diesel Generator (A59228)
2007 Ingersoll...
159120 (A60430)
159120 (A60430)
1990 21ft Center Console Fishing Boat with T/A Boat Trailer (A59231)
1990 21ft Center...
