Brush Hog
   / Brush Hog #1
dtd24
Schenectady, NY
98 JD 1070
I have a 99 1070 JD w/ 440 FEL and 8B hoe. I took off my backhoe and I hooked up the 3 point hitch for the first time. It went good, I think I will be able to do it quicker next time. I installed the brush hog, and it works like a champ. I went though a couple of shear bolts though. It says to run the hog at 540 pto rpm, on my tractor that is 2610. WOW ! I usually run it a bit lower. Runs great , but fast for some of my terrian. Gotta get use to it I guess.
   / Brush Hog #2
Welcome to the forum.
>>I went though a couple of shear bolts though<<
Did you hit something or did you break them trying to engage the cutter?
>>Runs great , but fast for some of my terrian.<<
Not sure what you mean there. Try a lower gear, perhaps??
   / Brush Hog
Shear bolts......yeah. Well, the first one busted because I engaged the pto with rpm's too high. The second one was from hitting a car rim. Ouch. The previous owner left me all kinds of goodies all over the place.
I understand the gear is the only thing that controls the speed of the tractor when using the pto. I thought I had it in low 1. Gonna try some more toinight.
   / Brush Hog #4
I am not familar with your tractor. Maybe someone who is will chime in here. Do you have a range selector as well as a gear shift? I would imagine, if you do, low range and low gear would just creep along.
   / Brush Hog #5
I'm not familiar with your tractor.. but if it has 1-2 stage clutch.. lower rpm, and use clutch to feather pto into operation. if independent, lower rpm, and see if your manual has a 'slow/feather' sequence for engagement.. etc..
Soundguy
   / Brush Hog #6
You DO NOT HAVE TO RUN THAT HOG AT 540 PTO RPM for a good cut. You can experiment with gears and rpm on the tach. I've got a 60hp 4wd with a HD 7ft cutter on the back. PTO speed of 540 is achieved at 2000rpm on the tach. I usually run this hog at about 1500 to 1800rpm on the tach in 3rd or 4th gear (8speed). If I was cutting 3" saplings I'd be in a much lower gear thougjh....BobG in VA
2015 FORD F-150XL SINGLE CAB TRUCK (A51406)
2015 FORD F-150XL...
Skid Steer Plate Attachment (A50322)
Skid Steer Plate...
2015 John Deere 135G Hydraulic Excavator (A50322)
2015 John Deere...
2022 KUBOTA KX040-4 EXCAVATOR (A51242)
2022 KUBOTA...
2016 CATERPILLAR 336FL EXCAVATOR (A51242)
2016 CATERPILLAR...
196046 (A50459)
196046 (A50459)
