Brush Shark
/ Brush Shark #1
Charles Park
Anyone familiar with the Brush Shark. Saw the ad in a Co Op Magazine and wanted to know if it works on brush, etc. The manufacturer says it does great.
I have Yupon trees and small stuff that I would like to remove. Hope to hear from someone. Thanks.
/ Brush Shark #2
went to their website - -sure looks good --any idea how much? I have my own bunch of yaupon.
/ Brush Shark #3
I have one- I used it this weekend on some cedar down south. It works as advertised if you use a skid steer. I can also use it on my tractor, (Kioti dk55) but without hydrostat it is hard. The teeth have to be moved left and right each time with the finger control in the bobcat and it seems easy. It cuts a 4 inch trunk instantly. I can't remember what I paid off hand. It doesnt require High flow.
rick
/ Brush Shark #4
Videos look good except one minor thing about what happens to the clipped off excess brush ? do we buy a grapple and a brush chipper to get rid of it ?
not for me and it looks like a huge hair clipper that cuts brush
very kool toy
Jim
/ Brush Shark
The new Brush Shark is about $3,800. Just want to make sure it works befoe I spring for something like this.
/ Brush Shark #6
that's about twice what I would consider spending for it - just because of the amount or non-amount I would use it. Looks like a good tool -- but I'd nearly have to be in business to justify that expenditure.
/ Brush Shark #7
So the Brush Shark works like hair clippers? And needs another hydraulic circuit to operate? We all know Newton County yaupon will grow back twice as fast and twice as hardy after being trimmed... Sounds like a lost cause to me! Have you considered nukes?
/ Brush Shark #8
If you are going to use it on a tractor make sure you have enough hydraulic flow. Not many tractors can match the high flow hydraulics of a skid steer.
MarkV
/ Brush Shark
MarkV
How can I determine the flow rate needed to operate this? The tractor is a John Deere with a front end loader. It is rated at 50 hp.
/ Brush Shark
Harley, had thought about spraying if I can get most of it down to a reasonable level. I believe there is a spray that will kill this and other brushy plants.
/ Brush Shark #11
rick
Rick,
I need something for thorny honey locust. What are your thoughts on the durability? How close to the ground does it cut? Do you think you would damage it if you sheared just below ground level? I would be using it on a Toolcat.
dsb
/ Brush Shark #12
If I understand it right, the brush shark clipper works only when activated so hydraulic flow would not be an issue - basically one cylinder load every now and then... Negotiating it around a bunch of trees on the front of a tractor may be challenging!
Spraying brush with 2,4,D or other herbicide may be easier if you want to take the 'nuke it' approach and it will kill out the roots. County agent or Forest Service would probably be knowledgeable about the options. Of course, brush clippers, rakes and hoes build abs, pecs and character! And some people pay for health club workouts! And then they are the goats...
/ Brush Shark #13
It will cut well and seemsto be sturdy. It will slide along at ground level and cut smooth. If you have hystat you can push against the brush and clip, which seems to work pretty well. I use a dozer for the cedar and brush that will come out clean, but the small one to two inch trees just lay over and don't come out. I am using the brush shark for these and it cuts real clean.
/ Brush Shark #14
Charles, the Brush Shark web site lists a required hydraulic flow of 5 to 30 gallons. Your owner's manual should list the flow rate for your tractor. Do you already have auxiliary hydraulics plumbed to the loader? If not that will most likely add another $500 to $1000 to the price tag.
MarkV
/ Brush Shark #15
I got one I rent out with a case skidsteer.
I am pleased with its performance on a bobcat.
I would not recomend it on the front of any tractor.
It will NOT cut a "T-post"
It will NOT cut Bryers
It WILL cut small trees, saplings, grapevine, mesquite, rip out the bryers that are tangled up in that mess of brush.
It will cut just benith the ground for a good clean up jub.
I like it
/ Brush Shark #16
The Brushshark requires a minimum flow of 8 - 10GPM and will work on most tractors 30HP + that are equipped with a 3rd hydraulic. It also is available with an "auto-cycle" option that eliminates the need to cycle it back and forth manually. This option is backward compatible and will work on all Brushsharks previously purchased. If you have any questions about the Brushshark please feel free to call or email. info@brushshark.com Land Clearing Equipment | Tree Shear | Skid Steer Brush |BrushShark.com
/ Brush Shark #17
Nice...need a larger tractor than my JD 3320. Would buy so.. Thanks for the info as I had never heard of BrushShark.
/ Brush Shark #18
The 3320 might work fine if you have the right options. It appears to have enough hydraulic flow and pressure.
18ft Gooseneck Utility Trailer (A64047)
18ft Gooseneck...
2013 Ford Taurus Sedan (A61574)
2013 Ford Taurus...
2018 Dodge 5500 Bucket Truck 4WD (A63118)
2018 Dodge 5500...
Arrow Quip 10' Bow Gate (A64047)
Arrow Quip 10' Bow...
2015 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A59228)
2015 Chevrolet...
2021 John Deere W48R Walk Behind Zero Turn (A63116)
2021 John Deere...
