Buying Advice BT650 Kubota. Questions can't find info anywhere
   / BT650 Kubota. Questions can't find info anywhere #1
MatLayfield
I found one in good shape for a deal but I have a few quedtions.
Will it fit a B7300HSD
Is it a 3pt or subframe mount.
   / BT650 Kubota. Questions can't find info anywhere #2
BT650 was the backhoe attachment for the B20, a commercial grade TLB based on the B series tractors. The backhoe was frame mounted to the B20. Since the B20 was considerably reinforced over its B tractor cousins, I would be somewhat surprised if there were a bolt-on subframe to mount that backhoe to a standard B. Worth checking out though. That should be a good little backhoe.
2020 JOHN DEERE 5125R LOT NUMBER 213 (A53084)
2020 JOHN DEERE...
Case Maxxum 140 (A50120)
Case Maxxum 140...
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
2016 Ford F-550 Palfinger PSC3216 4,000LB 2 Ton Crane Service Truck (A51692)
2016 Ford F-550...
2012 GOOSENECK TRAILER MFG.,CO, INC TANDEM AXLE MANIFOLD TRAILER (A52472)
2012 GOOSENECK...
