Bubbling Interior Ceiling Paint
   / Bubbling Interior Ceiling Paint #1
dieselscout80
Veteran Member
South Carolina
New Holland TC45DA
What causes interior latex ceiling paint to bubble?
What is the way to fix this issue?
   / Bubbling Interior Ceiling Paint #2
Have you been up in the attic (if possible) to look at it from the top side?
   / Bubbling Interior Ceiling Paint #3
Latex paint will bubble if put over old oil base paint. Do you know what you have existing? If not, always Kilz before new paint.
No idea what the old paint was since it was done by the previous owner.
Kilz was recommended to me by a friend too thanks.
I sanded the area which is near where the light/ceiling fans was, with a orbital sander until I got the paint to feather out.
Then I cleaned the area with simple green and covered the area with joint compound last night and will sand it and prime it with Kilz tonight and may re-prime the whole ceiling.
   / Bubbling Interior Ceiling Paint #8
What is under the bubbling paint? If it is another layer of paint, that is an adhesion problem. If it is the surface of the ceiling material (drywall or plaster), that is a moisture problem.
   / Bubbling Interior Ceiling Paint #9
Took me 40 years to learn, prime everything! I’m building a new house so, PVA over green sheetrock and I’m gonna shoot primer over that! I know, overkill but, cheap labor!
Primer is good. I’m told Kilz is best so that’s what I use.
Someone suggested I change the settings on my I pad to stop the hieroglyphs. Lost the post but I’m going to try anyway.
   / Bubbling Interior Ceiling Paint #10
A moisture problem with paint is not always from a leak. It can be because the humidity is higher on one side than the other. The moisture will move to the drier side, pushing off the paint in the process.
2019 CATERPILLAR 326FL EXCAVATOR (A51242)
2019 CATERPILLAR...
2014 PETERSON 4700B HORIZONTAL GRINDER (A51242)
2014 PETERSON...
Woods 7200 3 pt Finish Mower (A50514)
Woods 7200 3 pt...
2003 Club Car Electric Cart (A50324)
2003 Club Car...
2012 Audi Q7 (A50324)
2003 MACK RD688S T/A DUMP TRUCK (A51406)
2003 MACK RD688S...
