Bucket "curl" problem...
   / Bucket "curl" problem... #1
DirtHauler
Northern Cali ~~~ "Weed" Country
" '06" Kioti CK30 2015 Mahindra 2555 shuttle 2019 Massey 1760M
Bucket \"curl\" problem...
Last weekend after doing two solid days of dirt diggin' and moving, I suddenly have very little power in the bucket curling on my CK30. Dump, "power dump" and all other actions seem to be fine. Since I don't have a shop manual yet, can someone tell me what the PSI should be and at what RPM? I took it by the dealer for a look-see and he believes it maybe the packing leaking in the bucket rams......parts on order! (I think it's in the loader control valve) In the mean time, I have a friend who's a heavy equipment mechanic who'll check it out but needs to know PSI@RPM and if the pressure is too low, where and how do I adjust this?
   / Bucket "curl" problem... #2
Re: Bucket \"curl\" problem...
If the packing is leaking do you think it would leak down if you put a load of dirt in the air and just left it idel there. I would think fluid would pass through the packing to the lower pressure side and the bucket would slowly dump. Take a look for kinked lines coming out of the loader valve below deck. The lines are in harms way and can be smashed by the right stick from below.
I don't know the pressures for sure but the Kioti website lists it as 2000 psi controlled at the loader control. That should be at full PTO RPM for the testing.
2019 CATERPILLAR D6 LGP HI TRACK CRAWLER DOZER (A51242)
2019 CATERPILLAR...
Woods Brushbull 720 3 pt Mower (A50514)
Woods Brushbull...
2014 CATERPILLAR 303.5E CR EXCAVATOR (A51242)
2014 CATERPILLAR...
2017 SANY SY365C LC EXCAVATOR (A51242)
2017 SANY SY365C...
2022 McConnel TRAXX RC28 Remote Controlled Slope Mower (A51691)
2022 McConnel...
UNUSED AGT SAII100 QUICK ATTACH PALLET FORKS (A51244)
UNUSED AGT SAII100...
