Bucket cylinder installation
   / Bucket cylinder installation #11
Has anyone ever wrap the gland threads with cellophane wrap (kitchen supply) to protect o rings during installation. It is an idea I might try tonight, would like feedback. Good idea bad idea.
I use a sheet of very thin brass shim-stock. I would be concerned about the cellophane tearing and getting some inside the cylinder. Lube the O-rings with hydraulic oil as well.
   / Bucket cylinder installation #12
I have used the material from a coke can for a cyl guide. Very thin Aluminum. Cut the can into a flat sheet and wrap around the piston and slide it in the bore. Hold on to the Aluminum as you slide the lubed cyl in. Remove it and save it for the next time.
   / Bucket cylinder installation #13
Very bad idea. Very very bad idea.
   / Bucket cylinder installation #14
thanks fellows. I got some .003, .004, and .005 Precision brand shim stock. I wasn't going to put the wrap inside the cylinder only on the gland to put o ring on before reinstalling the rod. The shim stock will work much better and can use it the way you mentioned in your replies.
So i just got the cylinder repacked for the second time from the dealer and for the second time i hooked they hydraulic lines up to it and again it was leaking from the lock ring hole and the cylinder shaft didn't move.
so tomorrow i will go back the dealer and see what they have to say. they did the second repack free of charge but I'm a little worried that they don't know what they are doing or that there is something else wrong with the cylinder that they are missing.
it takes me an hour to get to the dealer so any ideas anyone has on what might be wrong with my cylinder would be appreciated so that i can clear this up without too many more trips to the dealer.
   / Bucket cylinder installation #16
I hate when stuff like that happens. I would ask them to hook up the cylinder and test it there after they rebuild again.
Self Leveling Rotary Laser (Survey Equipment & Grade Control) (New/Unused) (A59225)
Self Leveling...
2013 International WorkStar 7400 Altec D3060ATR Insulated Digger Derrick Truck (A55973)
2013 International...
2019 PETERBILT 579 TANDEM AXLE SLEEPER (A58017)
2019 PETERBILT 579...
2017 John Deere 35G Mini Excavator (A55973)
2017 John Deere...
2015 Ford Taurus Sedan (A56859)
2015 Ford Taurus...
2007 Mercedes Benz S550 (A56859)
2007 Mercedes Benz...
