Farmerford
Platinum Member
- Joined
- Dec 9, 2006
- Messages
- 733
- Location
- Columbus, Georgia
- Tractor
- Kuborta B2400, L2900, L4330; Caterpillar D3B, John Deere 455D
The loader on my 8 year old small Kubota B2400 uses 1" pins and the bushings are not replaceable. I prefer to replace pins rather than weld on new boom ends when the bushings wear, so when it was new I replaced the steel pins with phosphor bronze pins (80,000 psi tensile strength). I did some rough stress calculations and it appeared that the bronze pins would be more than sufficient.
The loader has been used regularly for 8 years, and most of the use has been at or near capacity (about 800#, I think). I keep them greased with a yellow metal safe 5% moly grease. There has been minor wear on the pins, but no measurable wear on the bushings. The pins should serve for another 8 years at least.
I bought the phosphor bronze on line (McMaster Carr, I think), drilled a grease hole down the center from one end, tapped it for a 1/8 NPT grease zerk, and drilled a 1/16 cross hole to admit the grease to the bearing. It was expensive ($25 per pin ?), but worth it.
I bought a well used John Deere loader a few years ago that needed new boom ends because the prior owner had worn through the replaceable bushings and into the bushing sockets. I managed to weld new ends on and get them aligned without line boring, but I don't want that project again. So the extra cost of bronze pins for the small loader is worth it to me.
