Bucket teeth on a 743 skid steer
   / Bucket teeth on a 743 skid steer #1
ChucknSc
bobncat 743
My best friend and I bought this BobCat 743 "Man's Toy" (as my wife calls it) to rebuild and use (play with) when needed. Anyway what I am interested in finding out right now is about the teeth on the bucket. I'm putting new teeth on now and find that some of the old teeth are held on with standard roll pins and some are held with what I've heard called "spiral pins". So I thought rather than go the trail and error way, I'd just ask you folks which is better to use in this case. Thanks for any help,,,,Chuck
   / Bucket teeth on a 743 skid steer #2
There are MANY different styles of teeth/shanks, as well as ways to hold them in place...Posting some pictures of what you have will help us help you;)
   / Bucket teeth on a 743 skid steer #3
Spiral pins are what Bobcat uses. I can't imagine a standard roll pin holding up for long. I would put spiral pins back in it, and I have found that Bobcat teeth hold up better than cheap aftermarket teeth.
Brian
   / Bucket teeth on a 743 skid steer #4
Dear Chucknsc, as you mentioned there are several types of pins for the teeth. Kindly ask you to contact AES Trading Tristars Tecnical Department. Our team will be appreciated to assist you. Pls visit our website Bucket Teeth in order get further details of pins & retainers for bucket teeth, ground engaging tools, cutting edges and blades .
Best regards,
   / Bucket teeth on a 743 skid steer #5
spiral pins fit into later generation bobcat teeth and hold-up well. older-stock teeth use roll pins, spirals won't fit into these teeth. for a skid steer both will work fine and if you're concerned about the roll pin shearing, insert a welding rod into the hollow of the pin before driving it home. gives it just enough strength to not shear-off under heavy work conditions.
NEW Wolverine Skid Steer Drive and Augers (A53002)
NEW Wolverine Skid...
2016 Chrysler 200 Limited Sedan (A51694)
2016 Chrysler 200...
2016 Bobcat E85 Midi Excavator (A50322)
2016 Bobcat E85...
2021 New Holland Workmaster 25S Compact Tractor (RIDE AND DRIVE) (LIKE NEW) (A50774)
2021 New Holland...
2007 FORD F-450 SUPER DUTY (A52472)
2007 FORD F-450...
2015 Ford Escape S SUV (A50324)
2015 Ford Escape S...
