3RR said:Regarding the the loss of power when moving the tractor, if the PTO has plenty of power then the engine is good and providing adequate power. I assume you checked your PTO power under load to determine it, in fact, does not bog down? If it does, John may be right about his analysis. But if it doesn't bog down under load, I'd be looking for something bent or the brakes stuck or something that prevents the tractor from rolling freely. Just a thought, did you try moving it, pushing or towing it in neutral to see if it's bound up somehow?
3RRL
Hi, I also meant whom ever sighted quick disconnects as well helped. Monday I will try your plan about the power loss and toe it to see if anything is hanging up.
Thanks Again!
Rick
