bucket won't rotate down
   / bucket won't rotate down #1
winter5470
punta gorda, fl
lk 2552
I inherited a new holland TC33D.
I was moving some dirt and spreading it.
Then the bucked stopped dumping (rotating down) when empty.
So I changed the hydraulic fluid and filters.
That stopped the squealing and "cavitation"
But the bucket still won't rotate down when empty.
I can scoop up dirt and with a full bucket I can dump and fully rotate down.
But not with an empty bucket, it will only rotate down a little bit.
The other thing I noticed is when I dump a load and pull the tractor forward, lower the bucked and back up to spread the dirt..... The bucket just rotates back up.
The hydraulics won't keep the bucket rotated down.
I can't find any hydraulic leaks.
Any thoughts on what to do next?
Thanks
Kurt
   / bucket won't rotate down #2
no specific knowledge, but if it were me, I’d disconnect and then reconnect the quick connect hydraulic lines to the loader. Hopefully that will be a simple fix.
Never mind!
The internet is a great thing.
Did a search for bucket won't rotate down.
A guy was having the same problem and was told to check the quick disconnects.
Sure enough one was unconnected.
Problem solved......
The funny thing was I changed the hydraulic fluid, filters, engine oil and filter, fuel filter and flushed the coolant. I never noticed the unhooked coupling.
Tunnel vision I guess.
Kurt
2006 Ford Explorer 4x4 SUV (A59231)
2006 Ford Explorer...
2017 Rogator RG1300B Dry Fertilizer Applicator (A56438)
2017 Rogator...
Hyster H155 XL Forklift (A59213)
Hyster H155 XL...
KOMATSU PC228USLC-3 EXCAVATOR (A60429)
KOMATSU...
HYDRAULIC AUGER FOR MINI EXCAVATOR (A58214)
HYDRAULIC AUGER...
Galvanized Livestock Wire Gate - 4FT x 11.5FT (A56436)
Galvanized...
