Budget counter weight.
   / Budget counter weight. #12
Stainless Rebar, can you say -->$$$<-- we are going to try using fiberglass rebar on a upcoming project for the same reason
   / Budget counter weight. #13
Ballast barrel is a great place to get rid of any old brake drums or rotors lying around too. If you haul scrap fairly often may be worth more to you selling it but it's a cheap way to add weight!
Oh I plan on adding quite a few bits and pieces from my scrap pile including seveal old brake drums. I think I've got enough scrap around to get the finished drum up to about 1300 lbs.
   / Budget counter weight. #15
I have some #4 bar to connect the two. I'm thinking the top link tabs need to come out of the side of the barrel eighteen inches above the cross bar instead of sticking up out of the top of the concrete.
Yes to your other suggestions.
Change that to 15 inches and you can use the JD i-match 3 point quick hitch.
   / Budget counter weight. #16
2019 Ford F-150 Crew Cab 4X4 Pickup Truck (A53422)
2019 Ford F-150...
Leeboy 685 Grader (A47477)
Leeboy 685 Grader...
UNUSED DIGGIT 6'5"-10 DRAWER, 2 CABINET WORK BENCH (A54757)
UNUSED DIGGIT...
2018 CASE IH 110N LOT NUMBER 207 (A53084)
2018 CASE IH 110N...
2019 John Deere XUV560E Utility Cart (A53421)
2019 John Deere...
TEST YOUR BID BUTTON! (A52705)
TEST YOUR BID...
