Building a carport
   / Building a carport
Many thanks for the advice BeezFun. I'll have to check on that. I don't want someone to get the wrong advice from my page. Fortunately, there doesn't seem to be any snow accumulation in my area, although the country requires structures to handle a 35# snow load. It's a hilly area, so it's probably a result of having map segments that cover areas that have much higher elevation.
   / Building a carport #12
I think you will find that the truss with the verticals was meant for the end, as the verticals are for attaching the gable siding or metal in your case.
I personally have never seen it done quite the way you did (hang a gable truss as a barge rafter/truss). in this part of the country. I would have expected to see the gable truss on top of the end wall. The barge rafters (typically a 2x6) are attached to the outriggers. The barge rafters are then covered with your fascia material/trim and the underside of the outriggers (between the gable siding and the fascia) would be covered with soffit material.
Hi NIdaho, Yes, I thought I did it right, given that one has to have the verticals on the gable end to which the siding is nailed. But I think maybe what BeezFun is getting at is the need for reinforcement in the last supported truss to handle the stress from supporting a cantilevered gable end. My plans from the truss company do mention that, calling for a 1x4 reinforcement to be sistered to the top chord. I was just lazy and didn't do that. I should go back and add that after the fact. I was thinking about whether I should close in the roof structure with a soffit. Without that I suppose I run the risk that birds will nest in the truss structure. The county prohibits combustible soffits. Maybe I could just pre-prime some 1/4" gypsum and use that. What do you think?
   / Building a carport #14
Interesting. Combustible soffits not allowed, but open soffits ARE? Where
is that? Soffits on a carport are pretty unusual, but non-combustible
soffits are a good idea (fire protection) on a house with overhanging eaves.
On my workshop building, I used galvanized sheet metal (26 guage) for
the unvented soffits....I have yet to paint them.
I know, it doesn't make sense to me either, but that's Shasta county, CA for you. Using metal for the soffits sounds like it would give a nice result, but I'd be concerned about the cost, since I have to enclose not only the soffits but the entire underside of the trusses, which would be about 600 square feet.
John Deere 772B Articulated Motor Grader (A49461)
John Deere 772B...
2016 GENIE GTH1056 TELESCOPIC FORKLIFT (A51242)
2016 GENIE GTH1056...
2021 JCB HM180T Hydraulic Breaker Excavator Attachment (A49461)
2021 JCB HM180T...
1994 PETERBILT 379 SLEEPER (A50046)
1994 PETERBILT 379...
CATERPILLAR 308E2 CR EXCAVATOR (A50458)
CATERPILLAR 308E2...
2014 VOLVO VNM DAY CAB (A51222)
2014 VOLVO VNM DAY...
