Building a set of forks for LA524
   / Building a set of forks for LA524 #11
I strap my homemade forks onto my bucket with chain and binders
No tools or drilling required
I posted the build summary last year or so
I used pallet racking from scrap cost about 20 or so in total if I remember right
Joel
   / Building a set of forks for LA524 #12
I made a set of brush forks for my old B7300 out of 2" scrap pipe and angle I had laying around. I can still use them on my B3300 but they won't be as wide as the new bucket (wouldn't really matter I guess). I took a 4' long section of 3x5 angle and placed the 5" web laying flat across the cutting edge of the bucket and cut 3 notches in the part that hung down. I welded 3 ~ 6 foot sections of pipe in the notches. The pipe went under the bucket to brace against the back edge. I then welded a short section of chain to the angle at each end and drilled a hole at each end of the bucket where I put a bolt through the chain to hold the forks in place when I dumped. I moved a lot of brush and small logs with those forks. The angle helped reinforce the bucket edge to keep it from getting bent.
However, I was limited in the amount of weight I could pick up. That's why I decided to make a carrier and forks that would replace the bucket when I need forks.
2022 Big Tex 22GN-35BK+5MR 40ft T/A Gooseneck Equipment Trailer (A51691)
2022 Big Tex...
2025 K5436 UNUSED (5) Wire Mesh Panels (A53117)
2025 K5436 UNUSED...
2014 Ram 5500 4x4 Altec 37G 37ft Bucket Truck (A51692)
2014 Ram 5500 4x4...
2015 John Deere 5075E (A50123)
2015 John Deere...
66'' skid steer bucket (A53421)
66'' skid steer...
2006 FORD F-150 PICKUP (A54313)
2006 FORD F-150...
