Building a temporary foot bridge over a small creek.
   / Building a temporary foot bridge over a small creek. #11
It would depend on the wood grade. If it is common lumber, 2x10s may only be good for 10-12' span. If you had 30 people on a 20' deck that I am guessing was 4' wide, you are running abuot 55 psf live load. Here is a table for 50 psf:
http://www.southernpine.com/downloadpdf.asp?filename=table06.pdf
And that is SYP, so it is towards the stronger end of available structural wood species.
Carrying a half dozen 20' 2x10s plus all that decking does not sound like my idea of fun, but that's going to be true to some degree of all options if you have to portage it in.
   / Building a temporary foot bridge over a small creek. #12
In the center I would put a couple of stabilizers into the creek bottom or people will think it's a trampoline and probably wreck it for you.
   / Building a temporary foot bridge over a small creek. #13
+1 Sounds like a rocky bottom creek so a support in the middle will also let you go much lighter on the shorter two spans.
Maybe have a back up plan too if you get a whole whack of rain the night before...
   / Building a temporary foot bridge over a small creek. #14
I've pretty much stopped putting things together with nails. Not only do screws (eg deck screws) hold better then even galvanized nails, they can be backed out if you ever have to replace a part or if you want to disassemble your construction project later.
I crossed forty feet of stream bottom a few years back with a 6' wide bridge/causeway. The actual stream crossing is only about 8' span, supported on driven steel posts on each side. The causeway part across the rest of the floodplain is supported on post spikes with short 4x4 verticals. Because it is a permanent installation, all the wood is PT...and all parts are screwed, not nailed.
The suggestions others have given, using 2x10's sound good to me. If you have an ATV, you could use your building materials to make a stone boat/sled to drag everything down close to the building site...carrying 20' 2x10's any distance wouldn't be a lot of fun.
BOB
   / Building a temporary foot bridge over a small creek. #15
We have a few temporary plank bridges over seasonal wet spots. Just 2 2X10s screwed to cross beams. These worked well but were like ice when wet. Someone put me onto a great non-skid idea: 24" chicken wire, put down with a staple tacker.
Anyway, there's a cheap temporary walking bridge.
You would only need to figure out a support for the center of the creek. For your situation, I might go three planks wide and add some workable hand rails.
   / Building a temporary foot bridge over a small creek. #16
BOB
I have leaned toward doing that, too, but will point out that the deck screws at my Home Depot/ Lowe's (usually) have a narrower shaft than the equivalent length nail *, and I don't know exactly what metal is involved in making the deck screws, but on my new fence several of the screws have snapped in the middle, from the shrinking of the newly-pressure-treated boards as they dry out. I've also had some snap while backing them out. They just don't seem to have nearly the same shear strength as nails.
It could also be that the twist force applied to the deck screw metal is harder on them vs the pounding (almost entirely compression force) a nail experiences.
* I don't know the precise shaft diameters, but if you just hold a 3" galvanized nail up to a 3" deck screw, the deck screw shaft is much smaller.
   / Building a temporary foot bridge over a small creek. #17
I wouldnt worry about the bridge getting wet if it high enough above water.
I would just go and get 3 20 footers wooden I joists. place it so its 4 ft wide i joist 2 ft apart. screw down the plywood and be done with it. Its temporary right? easy to put down and easy to take apart and put away. If you have the time, install railing on one side as there will be people who will want a rail to hold on when crossing. its lightweight and strong individually.
   / Building a temporary foot bridge over a small creek. #18
Don't forget to post a picture of your final project.
Good luck with the wedding!
2013 International WorkStar 7400 4x4 Altec AM650 50ft Material Handling Insulated Bucket Truck (A55852)
2013 International...
2022 Ram 2500 4x4 Crew Cab Service Truck (A55852)
2022 Ram 2500 4x4...
2015 Kia Sorento AWD SUV (A56859)
2015 Kia Sorento...
2024 78in Hydraulic Brush Grapple Skid Steer Attachment (A55851)
2024 78in...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A56435)
PENDING SELLER...
2012 SOUTHERN  130 BBL VACUUM TRAILER (A55745)
2012 SOUTHERN 130...
