building a well
   / building a well
stimw that's exactly what im talking about using mud pump to reuse water since I don't have water supply
   / building a well #12
If you cut teeth in the bottom piece of 2" PVC you can rotate it and it will work better.
I put female ends on the 2" X 10' PVC and used a steel nipple between them for more strength. You need "U" fittings at the top so the hose doesn't kink.
I had trouble with the garden well. I got down 18' with a garden hose and could not go farther. I dug a pit with my backhoe and put a piece of plastic in it so the water would run back into it so I could re-use it. I used a 2" pump from the pit to the pipe and it took 5 minutes to wash down the last 12' !!!!
2015 CHEVROLET SILVERADO CREW CAB TRUCK (A51406)
2015 CHEVROLET...
2017 Ford F-450 Crew Cab Mason Dump Truck (A55788)
2017 Ford F-450...
John Deere 3032E with loader and Box Blade (A55302)
John Deere 3032E...
1986 BARKO 160A KNUCKLE BOOM LOG LOADER (A52705)
1986 BARKO 160A...
2015 Ford Transit 250 Cargo Van (A55852)
2015 Ford Transit...
TOW BEHIND FINISH MOWER (A50324)
TOW BEHIND FINISH...
