Building my own sawmill
   / Building my own sawmill #21
:what are you going to use the mill for? yourself or forhire ? for yourself a manual mill will work for a lot less $. to make it a money job full hyd. not from your tractor $$$$. there is a big diffence ie:insurance vs none ect. :confused:
   / Building my own sawmill #22
I have decided to explore the PTO direct drive option with a moving log carriage. I will probably be asking some new questions in a forum other than hydraulics at this point. Thanks for the insight.
good start ;)
   / Building my own sawmill #23
I'm pretty sure you will find it very rewarding building your own mill. However factory mills take advantage of economy of scale and buying your own parts tends to end up almost as costly as buying new.
And if you get a major brand name, such as Woodmizer, Timberking, or even Hud-Son there is support from the mfg. even for used machines.
Slide on over to the milling forum pointed out earlier, lot's of help there.
2009 Peterbilt 335 Cab and Chassis Truck (A55852)
2009 Peterbilt 335...
(APPROX. 480BF) 1X6X6-16 WHITE PINE TONGUE & GROOV (A52706)
(APPROX. 480BF)...
2015 Freightliner M2 106 AWD Terex Commander 4047 Digger Derrick Truck (A55973)
2015 Freightliner...
Freighliner Tender Truck (A56435)
Freighliner Tender...
2017 Mitsubishi Mirage G4 Sedan (A56859)
2017 Mitsubishi...
LOT: (2) 2-Wheel Dollies, Roller Stand, (3) Screw Levelers (A59076)
LOT: (2) 2-Wheel...
