Building your own wagon - where to find supplies
   / Building your own wagon - where to find supplies #1
Larry_Van_Horn
Honeoye Falls, NY
Case 580D Backhoe, NH TC40D SS, JD 450BC dozer, Ford F700 dump
I would like to build a wagon (say 4' x8') to pull behind my CUT. I have looked around for a source for the axles, and in particular the front which pivots and steers which would be drawn by the tractor. I can weld up the platform etc, but want to find the running gear. Any suggestions?
Thanks,
Larry
   / Building your own wagon - where to find supplies #2
Larry, Not sure why you need such a "small" wagon (4X8). I had a 5X10 heavey duty (3500 lb GVR with 2" ball) trailer built for my Ford Explorer about 10 or so years ago. I also find it is perfect for hooking up behind the Farmall 230 to tow stuff around. Trailers are infinitly easier to back up and you don't have to worry about having 4 tires going in different directions. As a bonus, you can actually hook it behind your car to move stuff on the road. Just a thought Professor...Good luck on your decision/design. BobG in VA
   / Building your own wagon - where to find supplies #3
Larry
I am working on building a wagon like you describe.
I found the front axle from a old golf cart for the front
and an axle from a boat trailer for the rear. I am going to use
golf cart tires and wheels. I also got a lift gate motor and pump
for $10.00 and a cylinder for another $5.00 so I plan to make it
a dump. Total cost should be under $100.00.
Hope to start assemllly soon and will post pictures when I do.
Billk
   / Building your own wagon - where to find supplies #4
Trailer parts and plans
As they say about 10 lawyer at the bottom of the Potomac, here's a start /forums/images/graemlins/laugh.gif
   / Building your own wagon - where to find supplies #6
If I were looking for supplies to build one I would check out old junkyards and scrap metal yards, because I am cheap. you should be able to find some old axles, metal etc. in those types of places for alot less than new materials. There is an interesting looking homemade one built here that may give you some ideas. 4 wheel trailer and herewagon being built <--click on shop projects.
   / Building your own wagon - where to find supplies #7
I found gear in that size at HarborFreight.com. Under $200 brand new delivered.
DIYGuy
Link to my website:
Tractor Projects
   / Building your own wagon - where to find supplies #8
Welding site
These guys are a resource. There are several threads re trailer/wagons full of links and ideas.
   / Building your own wagon - where to find supplies #9
</font><font color="blue" class="small">( Any suggestions? )</font>
Sure! Try www.hardtofindwagonbuildingparts.com
No, kidding, but I know what you mean. There's a ton of things I would like to build, but I get stifled because I can't find basic things like pulleys, gears, shafts, and axles. McMaster-Carr is one of the best I have found, but lacking in variety. Sadly , my town doesn't have a junkyard.
   / Building your own wagon - where to find supplies #10
Saw a trailer once that used the rear axle out of something like a Geo, or one of the other small front wheel drive cars.
Steve
1983 Case 580D (A47477)
1983 Case 580D...
2018 Doosan DL220-5 Articulated Wheel Loader (A55787)
2018 Doosan...
2018 Caterpillar D5K LGP Crawler Tractor Dozer (A55787)
2018 Caterpillar...
2006 Chevrolet Silverado 1500 4x4 Pickup Truck (A55788)
2006 Chevrolet...
Golf Cart (A55853)
Golf Cart (A55853)
2021 International HV507 4x4 12ft Single Axle Dump Truck (A51692)
2021 International...
