Bulldozers on Antartica
   / Bulldozers on Antartica #11
Nice Pics, I always love good pics of machines. I should find the ones I have of the big coal diggers out in North Dakota.
Murph
Egon nailed it... These machines exert only about 4.3psi of ground pressure. A man walking around is about 5.5-6psi. They've never gotten a machine with a lower ground pressure so these beauties just keep on going...
   / Bulldozers on Antartica #13
Wow, so does that lower psi mean it COULD travel over thinner ice than a man could or would the sheer weight have a bearing on the thickness of the ice? /forums/images/graemlins/confused.gif
Weight is sorta independent of psi in this case. I think in this application, compaction or lack of compaction was/is the goal. To stay on top of the snow instead of having to pack it down (probably a few feet) so they could go forward. I don't think they do much thin ice crossing with a machine that weighs around 50tons. (guessing)
   / Bulldozers on Antartica #15
Scott, these are wonderful! But.. what are they using them for? I mean, obviously to plow snow.. but to plow the snow off from what?
Anyway, I want one! /forums/images/graemlins/grin.gif
Stuff like plowing runways, to pull sled camps around, anything that needs a tow or shove...
   / Bulldozers on Antartica #17
Scott,
Great pics.
If you look close it appears to be one of those small operator fans mounted inside pam. I guess thats for those summer heat spells when it breaks above 0 oF. /forums/images/graemlins/smile.gif
Fred
   / Bulldozers on Antartica #18
It was probably used to defrost or defog the windows. A lot of the 16 wheel rigs use them to do this around here.
   / Bulldozers on Antartica #19
I would say you are right on with your fan prognosis. The equipment had cab heaters but not set up to defrost the windows.
Way back when even some cars in the frozen north had little fans to help keep the windshield clear.
Egon
   / Bulldozers on Antartica #20
I've got one in my pickup truck(the heater blower hasn't worked for several years). Even cold air, moving across the glass, will keep the window defogged.
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
Year: 2008 Make: Chevrolet Model: Suburban Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 219,... (A51694)
Year: 2008 Make...
2004 CATERPILLAR D6R XL CRAWLER DOZER (A51406)
2004 CATERPILLAR...
2004 FORD F-650 SUPER DUTY DUMP TRUCK (A51406)
2004 FORD F-650...
2015 Nissan Altima Sedan (A50324)
2015 Nissan Altima...
2015 Ford Escape AWD SUV (A50324)
2015 Ford Escape...
