Burning Brush
   / Burning Brush #111
I post my story when the subject comes up. We all at one point do something we know we shouldnt because "I know what i'm doing" and "it won't happen to me".
Yes, it can happen to you, even if you know what you are doing and it ain't worth it. The recovery pain was worse than the initial burn pain.
Thanks for sharing your experience Mate. Especially for those of us who have 'done it before and nothing happened'. Kind of like not wearing your chainsawing chaps and helmet because it's 'just a quick job' on a cracked tree limb'.
Today I'm going to do a barrel burn. I prepped the area (10 meters around) and have laid out a hose with an extra section IOT get at anything that jumps the area. I also have a set of firefighting long cotton gloves and an 'anti-flash' hood, from my Navy days, that I will wear.
   / Burning Brush #113
I think the 20 minutes you waited for the fumes to dissipate was the biggest problem. The fumes increased, not reduced. As long as there's liquid gasoline it's going to evaporate into fumes.
   / Burning Brush #114
I have an on-going "discussion" about gas and brush piles. Several members at the breakfast club are absolutely convinced that you NEED gas or at least must mix gas with diesel. "Helps start the diesel". BS I can "start" diesel with one match held to a twig (but usually use a sheet of newsprint). I do not understand people who think like that.
Latest brush burning was last Sunday, very dry pile and partner (gotta have gas member) used me diesel can and was POURING it over the pile. I told him he didn't need dthat much. One match and the pile was roaring...then the exciement sstarted. about 20' away was a two stem tree, one stem had fallen, rotten at the joint, spark landed there and the smoke was getting serious. Time I got my saw fired up and laid into the down stem the fire was going full bore up the rotten center of it. I had seen clips of firefighters cutting flaming trees but that is the first time I ever socked a bar into the middle of flames. I cut up the down stub and the top off the remainder of it while partner was hauling water from a creek nearby. We both wanted to let it burn in hopes sthat it would take down the the standing stem but didn't dare, it looked like the tip top would brush the power lines. Got the fire out and sat down to a couple coffees to admire our work.
   / Burning Brush #115
Another saga of burning brush. Bad night, couldn't sleep, awake at 5am...hmm what to do...go to the breakfast club...but that doesn't open till 7am...Weather report said it was to be dry today AHAH! i'LL make breakfast, stop for coffee at the club and proceed on down to burn that pile of brush we left last Sunday. Done deed.
Loaded up stopped for coffee and remembered I hadn't loaded the diesel. Hour of bs at the club, back home for the diesel. Arrive at site, minor breeze blowing in my favor (away from the grove), Small splash of diesel (pile was mostly dead dry stuff), one match and in 2 minutes the entire pile was shooting flames 10' down wind....10 minutes later and I was stomping out the grass fires that were spreading down wind and cussing myself for not loading the flat shovel, rake and fork. Wound up beating ssome of the grass out with my jacket. Really wasn't all that much danger but I didn't want the creeping fire to spred too far.
A bit of preplanning and I would have had everything on the truck. That spur of the moment decision didn't work in my favor.
   / Burning Brush #116
I use a 500,000 BTU weed burner set on high flaming away until the the fire can take on a life of its own.
It is about the only way to reliably start a fire in the cold and snow.
I have to weigh in again with my method that utilizes a chimney style charcoal starter and some charcoal. I've started fires on cold, rainy days where the entire brush pile was soaking wet by inserting hot coals under the pile on a support (I use an old shovel missing its handle, but old piece of board or any metal might also work). By the time the charcoal is pretty much burned up all the brush above the coals is bone dry and on fire. Worst case scenario you add a second pile of burning coals, but that is rare, especially if you tend the file may inserting good pieces above the coals as it engages. Charcoal chimney starters are bog easy to DIY out of large can and some pop rivets. Heck, you even just make your own charcoal.
This last fall I wanted to do a couple of burns but the drought in the lower Adirondacks is still pretty bad so the brush piles were left to molder away on their own.
   / Burning Brush #117
One can look at a 'finished' burn pile and learn a lot about the burner. I am one that constantly 'cleans' up and pushes the fire together trying to burn everything 100%. I also almost always use the same spot for my brush pile... big or small so every thing burns up eventually. One thing I don't do but I probably should is extract the metal nails, brackets, etc. that get left. I also tidy up around the burn spot so there isn't grass, branches, etc. that could help spread the fire. Just part of enjoying the ritual for me.
   / Burning Brush #119
I burn all kinds of brush. I never use an accelerant of any kind to start the fire. I do use a propane torch to get the side of the pile that the wind is coming from to start. Once the initial blaze dies down I add brush slowly to keep the fire under control. I have burned lots of pine trees up to a foot in diameter over the course of 5 days. At night I let the fire die down to embers and then just revive it in the morning. So far in 6 years and a dozen fires I have had no problem. My neighbor uses some kind of accelerant gasoline or diesel I don't know which. They seem to drink and "play" with the fire.....
   / Burning Brush #120
Gas or diesel just poured on a pile flows thru most of the brush & goes into the ground below--wasted. Better to use a sprayer to apply it in a coating. Gas fumes: heavier than air, if you feel you must use gas, stay upwind and uphill. If you feel that you must use gas (that's a mistake), mix it 50 / 50 with diesel.
Propane torches / weedburners work great. Stick the torch in the pile upwind side, down low and if the pile is ready to burn you'll have fire in a minute or two. If the pile is stubborn, leave the weedburner burning on the upwind side at the bottom of the pile. Only the wettest, most stubborn piles won't eventually light. Here in the Northwet I have cut Scotch broom in the spring when we still get a lot of rain, piled it, and 2 weeks later attacked it with a hand carried torch and had 12 ft. flames in about 30 seconds. Another good thing about propane is that you don't contaminate the soil like gas or diesel poured on the pile does.
23169 (A50324)
23169 (A50324)
1999 CLEMENT END DUMP (A53843)
1999 CLEMENT END...
2015 FORD E350 16FT BOX TRUCK (A54607)
2015 FORD E350...
2004 Ford E-350 Passenger Van (A51692)
2004 Ford E-350...
2022 Padget Morris Electric Mobility Scooter (A54815)
2022 Padget Morris...
2015 JEEP PATRIOT (A51406)
2015 JEEP PATRIOT...
