Burning Brush
   / Burning Brush #81
That is what i am struggling with. If you have to go to all this to start a fire I am wondering how forest fires ever get started. All you need to do is put a match or a lighter up to some paper or dry grass or leaves and you have a fire. I light a brush pile about every month and never had an issue.
The climate has a huge amount to do with it. I could go out in the woods right now with a weed burner ( large propane torch ) and be unsuccessful in starting a forest fire. I have been out west in the summer, and I'm well aware of the fire danger there. A forest fire could easily be started with a single match.
   / Burning Brush #82
I noodle up a log and then soak the shavings in diesel for 5-10 minutes in a 5 gallon gas can I cut the top off of while I noodle up some more shavings. Dump the first batch and light it up and soak the second batch, then toss it it in handfuls as necessary until the pile takes off.
   / Burning Brush #83
Yes I am bamboozled - what is "noodle up a log"?
   / Burning Brush #85
thanks! I never heard that term before!
   / Burning Brush #86
Well, I have to tell this story. I pulled about a dozen 30 to 40 foot spruce trees out with the excavator and piled them up. Called the fire Marshall to burn it and he said you have to wait until the snow flies. I was good with that since I live in a log home about 250 feet away. So, summer turns to fall, fall turns to winter and it finally snows. Me and my buddy go out to light the pile, thinking this will be a couple hours and we will be drinking beer. 18 hours later, we went to bed after (and I kid you not): 40 gallons of diesel, 20 gallons of gas, bales of hay, 6 fireplace logs and a few gallons of citronella oil. **** stuff was pretty much fire proof. Every time we would get a fire going (and we started 6 at a time), all it would do is burn a hole up to the sky and go out. We ended up starting a fire and hand feeding it for 18 hours. Now, I've been burning stuff for 50 years, but I would have been much better off burying this stuff. The next day I had a pile of smoking stumps that I had to get rid of and a massive black hole in the meadow I had to repair. Go figure, we just couldn't get this stuff to burn!
   / Burning Brush #87
Harbor Freight weed burner is the way to go.
Logger piled green slash really tight, just before rains started. 42 piles. Here in western Oregon it rains all winter and summer lasts just a few months. Burning season starts in late fall and lasts into early summer, depending on weather.
Those piles just wouldn't dry out. Spring & summer and those piles were asbestos.
At the end of summer, the state forestry people wouldn't let me burn. Finally they would let me burn 1-2 piles per day on selected burn days since I didn't have a crew. I tried the toilet paper soaked in diesel--no go. Sprayed diesel & gas mix on the piles. No go. Got a weed burner and got my 1-2 piles per day. It's a regular flame thrower & no danger to you like you get with gas.
Then in November we had a forecast of heavy rain for several days. As the rain started, I went out there with my weed burner & started lighting them off, lit the remaining 18 piles. Burned quite well & the job was done, done, done!
   / Burning Brush
Why did you abestos? Cancer
Hey Everybody,
I am the original poster and have an update. It rained here on Monday so I went to the FD to obtain a permit to burn. I bought some fire starters at a box store, you know, made of wax, light and forget. For as hard as it was raining, I just lit a fire starter and placed it within the pile and it lit right off.
As that first pile burnt down, I lit another, and wound up burning 6 piles in all that day. All went very well, I used the Kubota to tend the piles as they burned down. Four of the piles smoldered for a few days but no issue.
On Thursday morning, I noticed the fire department at the burn area, hoses deployed, putting out the smoldering ashes. I went out to meet the guy in charge to figure out what was going on. The chief told me that it was very clear that I tended the fires and that there was no issue with me--- just that somebody called and the smoldering had to be addressed. I was on my way to a doctor's appointment, but I let the firefighters use the Kubota to work the piles. I might say that my wife thought for sure that I was going to jail for the piles still burning. Could not be further from the truth, the FD was really cool, great firefighters and leadership. They stressed there was no fault with me, just answering the complaint. I gave them a donation and thanked them for their service. Job well done.
   / Burning Brush #90
That is what I do up here in Puget Sound. As my slash piles are next to the forest so do not want to get any thing else burning; I always burn when it has been raining for awhile and the surrounding areas good and wet. Can always get a permit then.. Weed burner and some times a leaf blower. Never fails. Once you get it started the top stuff dries out fast and the fire storm starts. I have had flames 30' in the air. If I have waste oil that is how I get rid of it. We are not supposed to burn stumps but I cheat. I have had stumps burn for a week. They do not smoke and fires are well back from the road. Heat, air, and fuel are they key elements of fire.
Ron
   / Burning Brush #91
I started getting my burn piles together a couple months ago. They will be dry by the time burn season rolls around this year. Last year I started the fire with 4-5 old pallets cut up like a Bon fire and a gas soaked T shirt. Worked like a charm. This year I will do the same but I now have a mini X with a thumb to feed the fire. .. Hope it goes faster now.
   / Burning Brush #92
My tried and true method of starting brush piles is simply use one of those charcoal chimney starters to get the charcoal red hot and insert it under the pile. I have an old shovel that is missing its handle as a base for the charcoal if there isn't a board or something in there for the charcoal to sit on. I've used this method to start piles of wet brush while it was raining.
We have a shallow aquifer in very sandy soil, so I generally don't want to pour gas or oil on the ground if I can avoid it.
   / Burning Brush #93
I use a leaf blower to move the fire around when burning brush. Forced air helps if it is too thin to burn naturally.
   / Burning Brush #94
Touched my pile off last weekend after the ban was lifted. We finally had some rain so things were a bit damp. A little used motor oil and a weed burner along with some cedar and sequoia branches got it going in no time at all!
   / Burning Brush #95
I would warn anyone about getting too close to fire with hydraulic equipment. I have a burned out Steiner 430 Diesel in my Shed that a friend had driven too close to a bon fire. I know, that's a little machine, but some of the biggest machines on earth have been taken by fire, via their hydraulics.
   / Burning Brush #96
I often dump additional material or tidy up my burn pile while still burning strong. Probably not good practice but I get a lot of burning done that way. Now that I have most all of my clearing burned it won't be as often. Note in the pic in post #94, my BX is actually quite far away.
   / Burning Brush #97
For you guys that use diesel to light...
Do you have a 1-2-5 gallon can that you just use to pour over the material?
If so, I urge you to consider using a garden sprayer. You'd be surprised at how much flame you can get from a squirt of diesel.
I would wonder if you are wasting some of your fuel. My (I think it's 2 1/2 gallon) sprayer, would probably last me a number of fires, I'm guessing 5-6 depending on what's being burnt
if you are not just pouring it onto the material, then never mind my comment
   / Burning Brush #98
I use a gallon jug of used motor oil to start our bonfires. The previous owner left a 55g drum full and I have been just pumping it out a gallon at a time.
I put a flake of junk hay every 3-5 feet around the perimeter of the bonfire (usually they are 10-15 feet across) and splash some motor oil onto it. Then I walk around with a propane torch and light the flakes of hay on fire.
While a little oil might drip onto the ground, I am pretty sure it gets burned up once the fire gets rolling as they are generally too hot to get within 6 feet of without losing hair.
Aaron Z
   / Burning Brush #99
Before:
After (used diesel):
Next:
2007 Volvo VNL Truck Tractor (A56438)
2007 Volvo VNL...
2024 CATERPILLAR 306CR EXCAVATOR (A60429)
2024 CATERPILLAR...
Topsoil Trommel (A57453)
Topsoil Trommel...
PALLETS OF HEAVYEQUIPMENT (A58214)
PALLETS OF...
2013 John Deere 824K Wheel Loader (A56438)
2013 John Deere...
JCB 507-42 TELESCOPIC FORKLIFT (A60429)
JCB 507-42...
