Burning Poison Ivy
   / Burning Poison Ivy #11
If one is imune to poison ivy (as I am) as far as getting a rash/blisters from touching it, does that also make one imune to the smoke, or are the 2 not related?
That imuneity does not stay with you, it comes and goes. I was till I hit 46 years old now I can't walk past it without scratching.
   / Burning Poison Ivy #12
If you can get the dozer back on your place, it is safer to dig a trench and bury the piles. That's what they do around here.
   / Burning Poison Ivy #13
Have burnt it many times, just be aware and stay out of the smoke. It is not a twig or two that will hurt you, it is when you burn a bunch of it, but when in doubt stay out of the smoke.
   / Burning Poison Ivy #14
I would burn it without worry but take the precaution of 1)staying out of the smoke 2) make sure the smoke doesn't carry over to a neighbor so only do it when the wind direction will carry the smoke away to a uninhabited area 3) make it a hot fire by waiting at least 1 year to burn so it is nicely dried out so it minimizes the smoke and carries the fumes high into the air to dilute the vapors.
   / Burning Poison Ivy #15
By glancing at the picture it from what I can see it doesn't appear to be any poison ivy. The brush looks more along the lines of saplings than a tangled vine mess typical with poison ivy. That doesn't mean it isn't in there. The oil is in the leaves, stems and roots so just because it looks dead doesn't mean it is not there.
As others have said find a calm day torch it and stay upwind. I've burned it before in a brush pile by dousing the pile with diesel/used motor oil mix to make sure it would light and stay lit. Once it's burning the draft will pull the smoke up and away but if you end up with a smoldering fire it will be hard to get it to take off without exposing yourself to the smoke. I would advice getting your permit and lighting it soon. Typically by the 3rd week of april through mid-may there's a burn ban. I don't know about your county but in mine if there is snow on the ground than you do not need to apply for a permit at all.
   / Burning Poison Ivy #16
When I was a young a kid up the street got it bad all over his face and neck from smoke from a burn pile. He looked like an alien for weeks.
   / Burning Poison Ivy #17
X's 1000 what the uys have said about the smoke, poison Ivy, Oak and Sumac, same thing.
I could play in the stuff when I was a kid, then one day got in the smoke the neighbor was burning ad spent the next 2 weeks wishing I could breath, I was 10. Now the stuff will get me even when I drive by it:mad:
I have been told you build an imunity to it over time......been 40 years:confused3::laughing:
   / Burning Poison Ivy #18
I've been immune to poison ivy for years, but I'd still avoid burning it unless I absolutely had to. I cut some firewood once that had ivy on it, I wasn't concerned because it doesn't bother me, but my wife added some wood to the insert one day and got eaten up by the smoke.
   / Burning Poison Ivy #19
I am partially immune, I only seem to get it on the tender skin between my fingers. One time I got it on my gentlemen parts, I will never make that mistake again.
   / Burning Poison Ivy #20
The problem is the the irritant is in oil form and when you burn it it turns into a vapor which can be inhaled!
On the skin is bad enough but in the lungs is what can kill.
2009 Subaru Outback AWD SUV (A50324)
2009 Subaru...
2012 Ford Fusion SE Sedan (A51694)
2012 Ford Fusion...
Kivel Hay Spear (A50121)
Kivel Hay Spear...
Swict 84" Bucket (A50121)
Swict 84" Bucket...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50323)
2016 Big Tex 24ft...
2016 Ford Explorer...
