Burning wood , Add-A-Furnace; Monarch, Longwood
   / Burning wood , Add-A-Furnace; Monarch, Longwood #21
I have a hardy wood burner (boiler), it is out side burner( but I have it in my garage. The water is heated and pumped into my house to a radiator in my
plentum, when the thermastat calls for heat a pump start and the blower
on my furnace kicks in you can not tell the diferance between wood,gas,oil
heat.Plus it also heats my hot water ( I have turned my water heater off at times) When the water is hot enough the blower to the fire box shuts off @
damper closes. Mine has a spot to put a 2nd pump on so you can heat a 2nd
building. Burn time in my old farm house at 20 degrees is over 12 hours.
You can burn any kind of wwod you want dry , green it don't care. Clean
out has second door so that is no problem. I have had mine for about 20 yrs.
no problem.
2015 Freightliner Bucket Truck (A52128)
2015 Freightliner...
2001 MACK MR688S TANDEM AXLE ROLLOFF TRUCK (A52141)
2001 MACK MR688S...
2022 Wacker Neuson SM100 Mini Skid Steer (A52128)
2022 Wacker Neuson...
2007 Toyota Camry (A50324)
2007 Toyota Camry...
(10) 28' Continuous Fencing Panels (A50515)
(10) 28'...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
