Burnt off some turkey
   / Burnt off some turkey
It was a piece of 10" schedule 80 black iron pipe kicking around at work.
Steve
   / Burnt off some turkey #12
Curious how you made your stub shafts.
Only way I've seen is to machine two round disks that will slip fit in the tube. Then drill or burn holes in the tube so the inner disk can be plug welded. The outter disk is welded around the circumference.
The shaft is welded to the two disks first.
Anyone got an easier (less machining way) to accomplish this?
THANKS.
Ron
<font color="orange"> Only way I've seen is to machine two round disks that will slip fit in the tube. </font>
Ron, thats exactly right, machine shop where I work is always very accomodating. I wanted them water tight as I drilled a 3/4" hole in one end to be able to fill with water for weight.
Steve
   / Burnt off some turkey #14
what is that, a soil compactor?? /forums/images/graemlins/smile.gif
Finally got to use the aeorator today. This pic was on grass that is rooted fairly well.
This was on an area that the grass is not very dense yet.
This is a finished view of the beast.
Steve
   / Burnt off some turkey #18
A mighty fine job your doing there.
2022 Greenworks CU400W Commercial Work Utility Vehicle DEMO UNIT (A56436)
2022 Greenworks...
New/Unused Electric Golf Cart (A57453)
New/Unused...
2004 International 4300 Box Truck, VIN # 1HTMMAAMX4H667102 (A57453)
2004 International...
1992 Ford L9000 Cab Chassis with Low Mileage Cummins (A56436)
1992 Ford L9000...
2018 Chevrolet Camaro 1LT Coupe (A56859)
2018 Chevrolet...
SKID STEER BUCKET (A58214)
SKID STEER BUCKET...
