Burnt on Carbon BBQ grill
   / Burnt on Carbon BBQ grill #11
I will not get offended if someone refuses to eat stuff that comes out of my smoker. All the more for those that will.
:thumbsup::licking::yes:
On a serious note,I do understand that the mere sight of certain things can turn people off. While my teens were in high school,wife bought thin sliced deli meat intending us to use 1-2 slices and lots of lettuce and tomatoes on sandwiches. Our son would stack half a pound on without veggies which upset the daughter. One day when boy wasn't home,while putting up groceries,daughter used a smashed toothpick to brush green food color on edges of meat. Of course the boy told his mom that meat was spoiled. Daughter was overjoyed,,,,,,,,,,,until it was discovered no one injoyed the meat eventhough we knew it was fine. Wife threw it out and threatened to put the whole bunch on bread and water if it happened again.
   / Burnt on Carbon BBQ grill #12
Anyone have any secret way of getting off burnt carbon on a BBQ Grill parts, grates and spill plates. I tried heating the drill to high temp that's didn't help. I don't want to sand or use tools as the stainless steel will scratch.
So far I tried BBQ cleaner and Oven Cleaner OFF, Carbona, Goo Gone, and ZEP Heavy duty.
I've let it soak in plastic bags for 5 hours in one case, other I let soak 30 minutes to an hour.
I'm sbout to start using Carb cleaner.
Is this a gas grill? Don’t use carb cleaner. That is nasty stuff that should come nowhere near food. Actually, I don’t think I’d eat the food cooked on your grill seeing what you’ve already used.
One sure way is to clean after each use. Dawn dishwashing detergent will work in this case unless really baked on.
As suggested, a brass brush for the grill cooking grates is all I use.
   / Burnt on Carbon BBQ grill #13
I don't clean mine after use as it prevents rust, clean before use.
   / Burnt on Carbon BBQ grill #14
All that "carbon" is by design...it adds flavor (witness the Weber "flavor bars" that they have used for years). I have a big grill brush with a scraper on the edge and heavy brass bristles on the pad. I pre-heat, scrape the top of the grates then use the brush. No "junk" ever comes into contact with the food and even if it did I'm still alive after all these years.
   / Burnt on Carbon BBQ grill #15
Exactly what I do. Scrape the drip pan once every blue moon.
   / Burnt on Carbon BBQ grill #16
I do much the same except I wet the brush first, the steam seems to release a lot of the crud, the purists tell me I should use beer but 1. it's a waste and 2. water works just as well.
BBQ is a Ziegler and Brown and has a screw in disc in the base that catches the fat, unscrew completely and wash it out a couple of times a year, thew grease also lubes the thread that holds it in.
The disc is like half a hollow doughnut with a coarse screw up the centre, when closed it stops bugs getting in, just remember to open before using.
Yes it's a GAs grill
Solaire 3 Inch InfraVection Natural Gas Grill With Rotisserie On Standard Cart - SOL-AGBQ-3CVI-NG : BBQGuys
It's a Solaire grill I found on Craigs list. The grill lists out at $3,900.00 and was for sale for $200.00. I didn't believe the ad thinking they meant $2,000.00 but you never know.
Sure enough the guy wanted $200.00 and I couldn't get the money out of my pocket fast enough. I knew these grills were expensive but when I looked this grill up when I got home my jaw hit the ground.
Who in their right mind would spend 4L on a BBQ grill? . It was connected to his house gas line outside. I did a test and it worked fine.
I get using a grill with built up burnt racks on grill in fact on my smoker I never clean the racks for flavor, but since this isn't "my mess" on the grill I want to start fresh with a clean grill.
It's all stainless steel and the way the carbon is burnt into the grill racks is like black powder coat infused in the stainless steel metal.
I did several brushed and nothing will even scratch the carbon.
Some suggestions here are to bake the items in tin foil. The frill supposably gets up to 1,000 degrees so that might do it . I'm waiting for a part to connect it to my house, so I'll try the high heat. I was about to get out my acetylene torch.
I agree 100% but this is a used grill and it's someone elses carbon, sorta like wearing someone elses underwear, just creeps me out. I want to get down to 100% clean then build it up with my carbon.
   / Burnt on Carbon BBQ grill #19
Are you sure the grids are stainless? My BGE came with coated grid, I think porcelain, that was a dark color and after a few uses looked flaky, I threw it out and bought a stainless, which I pretty much only use for jerky, and I bought a cast iron which I use for most everything else.I've seen those coated grids that people continue to use and they get pretty crusty and will not clean.The stainless will clean up pretty easily.
1993 Trail Boss Lowboy Trailer (A52384)
1993 Trail Boss...
2005 TerraGator 8104 (A53472)
2005 TerraGator...
TEYME 2000 E0L0 GTE10 LOT NUMBER 228 (A53084)
TEYME 2000 E0L0...
FRONTIER LP2196 LOT NUMBER 113 (A53084)
FRONTIER LP2196...
Husqvarna 440 Chainsaw (A51573)
Husqvarna 440...
2004 CATERPILLAR D6R XL CRAWLER DOZER (A51406)
2004 CATERPILLAR...
