Bursting Hydraulic Lines while snow plowing
   / Bursting Hydraulic Lines while snow plowing #11
The problem with the cracks is water gets inside the wire braids (steel) and corrodes over time....thus weakening the braids that give the hose strength....
during HD usage you'll find the weak spot in the hose......Poooofff....:confused2:
   / Bursting Hydraulic Lines while snow plowing #12
Also be aware that some OEM hoses are 1-wire braid reinforcement (SAE100r1)......and most custom replacements are 2-wire braid (SAE100r2)= Higher pressure rating......
   / Bursting Hydraulic Lines while snow plowing #13
Check the pressure rating on your hoses if you can still make out the writing.
I was blowing a hose on my FEL about everytime I used it last summer. The hose rating used by the mfg. was 2000 PSI. The guy making my replacement was using the same brand of USA made hose but his was 2400 and so far none of the replacements have failed The hoses are only 2 years old and stored under shed or inside all the time. My first blow out was in the first year. Your hoses may be like mine, just a tad under spec or at the upper limit. Mine were all just pin hole blows and none at the union.
   / Bursting Hydraulic Lines while snow plowing #14
I vote for age as being your issue. My hydraulic tractor is around 10 years old and I am now replacing many of the hoses.
I would also suggest shopping around for hoses, prices vary wildly.
Remember your safety on these things. Oil under pressure can really mess you up.
   / Bursting Hydraulic Lines while snow plowing #15
As others have said, it's probably just age. I've replaced numerous hoses on my old backhoe. In fact, I've bought caps and adapters to either plug a line or make a temp fix in the field until I can get a hose made as they'll usually burst under load when I'm least expecting it.
   / Bursting Hydraulic Lines while snow plowing #16
I think the age (10 years) and the fact that it's stored outside is the reason...bend your other hoses and look for cracking-I will bet you'll find some.
I agree 100%. Being outside is tough on them. Cold also is not helping them either. You are going to have problem after problem. I would just bite the bullet and replace them all. Its going to cost you...
I agree though, get a gauge on it and check the pressure.
Chris
   / Bursting Hydraulic Lines while snow plowing #17
It also could be caused by the high pressure spikes generated when contacting a large stationary object. You just might be sending a 4000 psi spike through the hose, and the weakest spot gave way.
I want to thank you all for your replies. There is such a wealth of knowledge on this site, its amazing.
I think I'll take the wait and see approach with the remaining lines. I inspected them all and they seem ok. Although ,with my luck Ill probably end up replacing one every other snow storm!
I have to say that owning a tractor is always a treat. Whether using it to make chores more manageable, or learning how to fix the darn thing when I mess it up. Thanks again for the help.
CV
   / Bursting Hydraulic Lines while snow plowing #19
Chris
For sure at least change the ones together as a set.....and if it makes you feel better you can save the old ones for possible spares if you whack any...you'll more than likely chuckem after a while anyway.....;)
   / Bursting Hydraulic Lines while snow plowing #20
Definately hose age. All components being healthy, you will grenade a cylinder barrel before blowing a hose. Seen it dozens of times.
2016 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2016 Peterbilt 320...
2007 FELLA SM350 3 PT DISC MOWER (A53473)
2007 FELLA SM350 3...
2015 Ford Escape SUV (A50324)
2015 Ford Escape...
KMC 5610 (A53084)
KMC 5610 (A53084)
2011 DRAGON PRODUCTS 130BBL VACUUM TRAILER W/FRUITLAND VACUUM PUMP (A53843)
2011 DRAGON...
2008 Ford F-450 4x4 Crew Cab CM Service Truck (A52377)
2008 Ford F-450...
