- Joined
- Aug 31, 2001
- Messages
- 66,061
- Location
- South Bend, Indiana (near)
- Tractor
- Power Trac PT425 2001 Model Year
Yes Cedar is beautiful.I sort of "rescued it" out in the woods. I found it bulldozed into a pile of brush, as waste. It had no rot. It felt good to cut it into beautiful boards.
The entire purpose is to reduce the noise of 16HP. Pretty sure venting / cooling ducts / exhaust thru the door is not rocket surgery but I'd like to see how others have done it. Retaining the 'quiet' with holes in the door probably IS rocket surgery.
Wish I knew how the grounding should be done.
What's the manual say about grounding? Nothing. It says the ground is connected to the AC outlet ground and has to be connected to any building properly by an electrician. It says nothing about grounding the generator itself, does it?
