Bush Hog 1846QT Hydraulics Reseal & Fluid Replace
   / Bush Hog 1846QT Hydraulics Reseal & Fluid Replace #1
Banochris
Kubota L245
Hey there all,
I just picked up an old Kubota L245 with a Bush Hog 1846QT FEL. According to the original spec sheet, the cylinders are Ognibene & Hol-Mac - 1.5 inch Bore, 15.0 inch Stroke Double Acting Cylinder, 1” rod, 9/16 - 18 SAE ORB. The Seal kits are supposed to be Bush Hog Part# 25H41702. I haven't taken one off yet because I wanted to gather all the info I could before potentially getting stuck. Do I need a special tool to get the nylon ring on or do I just need to be careful about putting it on as straight as possible?
   / Bush Hog 1846QT Hydraulics Reseal & Fluid Replace #2
Are you talking about the white backup ring?
Hey there TractorTech,
Yes. The one on the end of the piston that wraps around the aluminum ring. I figured out there are actually 2 seals, the black rubber one is under the white one. I was able to get them all rebuilt, and I've got them back on the FEL. Still need to fill it with hydraulic fluid and check for leeks.
What I did was put it on by hand as carefully as I could, but it still stretched a little. so I put a bunch of popsicle sticks around it, then wrapped a hose clamp around them. Then I just tightened it a little to press it back to original shape. It worked like a champ and the piston went right into the cylinder. When I get the hydraulic fluid in and fire it up, I suppose I'll know immediately if t=it worked. :)
Thanks again,
Monty
   / Bush Hog 1846QT Hydraulics Reseal & Fluid Replace #4
You know what you’re doing! Basically the hose clamp is sufficient to squeeze it back down.
Putting them on “as carefully as I could” is what you do.
Finished the repairs and it runs great with ZERO leaks! Just like TractorTech said "Take your time and be careful."
Thanks again for all the feedback.
Monty
2016 INTERNATIONAL PROSTAR TANDEM AXLE DAY CAB (A59904)
2016 INTERNATIONAL...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
3Pt 4' Harrow (A59814)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
CATERPILLAR 255 SKID STEER (A52709)
CATERPILLAR 255...
Deere 335P (A53317)
Deere 335P (A53317)
