bush hog blade bolt removal
   / bush hog blade bolt removal #11
The bolt should have a key to keep it from turning.
   / bush hog blade bolt removal #12
Rutwad,
It may well have a key, but if so, it isn't working. Thanks.
   / bush hog blade bolt removal #13
you could tack weld it. Or just sharpen the blades without removing using a side grinder or torch.
   / bush hog blade bolt removal #14
Go to your local Bush Hog dealer and purchase part #6432. This is a special socket wrench, used with a large crescent or pipe wrench to assist with blade removal. Under $30.00 and worth it because it saves you sanity, your knuckles and keeps you from swearing often and loud!
Since having the problems with blade/bolt removal a while ago, I've found that using anti-seize on the threads and interior of bolt head makes all the difference. Simple matter. If you buy a new bush hog I'd suggest first thing you do is remove the bolt and put anti-seize on it before using the mower. . . .
BTW, my sq4800 does not have a key, seems to work fine w/o one, and the anti-seize lets you tighten the crap out of the bolt, blades still flail, and removal is as smooth as crap through a goose.
2017 Ford F-250 4x4 Knapheide Service Truck (A50323)
2017 Ford F-250...
2016 John Deere Z915B (A50121)
2016 John Deere...
2019 Ford F-350 XL (A50120)
2019 Ford F-350 XL...
(4) Beams (A50121)
(4) Beams (A50121)
378749 (A51573)
378749 (A51573)
2015 ISUZU NPR 16FT BOX TRUCK (A52576)
2015 ISUZU NPR...
