Rotary Cutter Bush hog pull behind info to help me spend my money :)
   / Bush hog pull behind info to help me spend my money :)
Zebrafive said:
Factor in your time and fuel. I made a 10 hour round trip when I bought my Bush Hog 297, but the price and condition made it worth it.
Zebra, I remember seeing that pic a few times on here, that's a nice setup with your tractor!
LD1 said:
I guess my question would be....are you really wanting a pull-type??? Or is this just a compromise because you cannot find a good used HD 6' 3PH type???
Too bad you arent any closer to me. Their is a 306 3PH type on c-list for $600 right now. (and now its not mine:laughing:) but it looks pretty good though.
Ld,
Your right about not being able to find a good used 3 pt type. I would prefer the 3 pt type for tighter woods mowing that I do but was thinking a HD 3pt type might be a bit much for my tractor. However, I guess you prove me wrong there by using it with your 3400.
I was actually thinking I could convert this to a 3 pt style if it didn't work out.
I'd really love to find a nice condition mower like Zebras in good shape. Something like a 306/296 but it seems like I'm missing all the good deals. My budget right now is under a grand and I haven't come across one yet (that aren't already sold)
   / Bush hog pull behind info to help me spend my money :) #13
Converting to 3PH is always an option if you are handy with a welder. But I would re-configure teh tailwheels. Those for being pull-type add alot of extra weight back their. Your tractor being about 600-700# heavier and a good bit more power......I wouldnt hesitate at all to run a 306 behind it. Weight is my only issue with the one I have. Leaving the FEL on is a must.
IF you do decide to proceed with this cutter, just check out the gearbox real good (stump jumper pan for wobble), and check the u-joints. About everything else that could possibly go wrong can be fixed with either a welder or paint:thumbsup:
I "assume" you saw my thread, but if not...here http://www.tractorbynet.com/forums/attachments/220111-bushhog-306-fresh-painting.html
As you can see, as long as the gearbox and PTO are good, it dont take much $$$ to turn a seemingly POS into a nice unit.
   / Bush hog pull behind info to help me spend my money :) #14
You also need the tail wheels to swivel, not just trail when converting a pull type to 3pt.
   / Bush hog pull behind info to help me spend my money :) #15
if its a bushhog its a 307 or 3008.buy the looks off it id go with the latter an it looks in good shape.
Well so far no pics from the seller as he promised me yesterday!
2002 CATERPILALR D8R HI-TRACK CRAWLER DOZER (A52707)
2002 CATERPILALR...
Towable Sign Board (A55851)
Towable Sign Board...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
2020 Freightliner M2 106 Elgin Whirlwind Series MV Street Sweeper Truck (A55852)
2020 Freightliner...
1827 (A51248)
1827 (A51248)
2015 International WorkStar 7600 Tandem Dump Truck, VIN # 1HTGSSNT8FH507443 (A54865)
2015 International...
