hslogger
Platinum Member
One other thought comes to mind for you and your vibrations. I rebuilt an old unit last year, and found that the four bolts that hold the gearbox to the deck had worked themselves loose enough that they needed to be tightened. Trouble was, the threads were pretty buggered up, so instead of running a bunch of washers to shim it,I cut he old bolts off or heated and removed them, replaced them with new bolts and lock washers. That fixed the problem.
Another aspect, like previous posters said, the arms are on bolts and if one gets stuck it won't swing out and that is a major contributor of this kind of problem. Now that I have my thirty year old unit sandblasted, primed and painted with epoxy underneath and above, with all new main bolts and swing bolts, I hose it down once in a while and figure with water and grease it will last another thirty years
