Well than,try a chain for top link,set it up about level about 4-5 inches off ground[bottom of deck,not wheel],than adjust that chain so its got 2-4 inches of slack[you just gotta mow and adjust chain to see],now keep in mind that even with mower up 4-5 inches,going over rough whoopdy doo's front can dig in ground,so go slow on the rough areas till you get the height/chain adjusted right,at this point about the only thing the chain is doing for you is stopping the back from dropping down so far that drive line comes apart,it may let you raise it 4-6 inches[wheel that is off ground] with 3 point lift.Also keep in mind that rear can come up,so don't be backing into hill or brush.
Just take the top link off and mow some on fairly smooth ground,you'll see,than put a chain on it and play with adjustment of it,you'll see,and do it however you want,just telling you how I do it and what to watch out for.
