Bushhog 306 fresh painting
   / Bushhog 306 fresh painting
Outstanding job!! I like it! Yep, that tractor won't the BH, but I would be worried more about the 1000lb BH hurting the tractor! Does the Kubota pick it up pretty easily?? Do you have weights up front? Or a FEL to offset the rear weight some??
FEL on for ballast and it handles it fine. I think my 3PH is rated @ 2000lbs at the pins and 1500lbs @ 24", so I am within its limits.
But without the FEL on, I can still lift the BH, but there is only about 200lbs of weight over the front tires. I can literally grab ahold of the front brush guard and lift the whole front in the air:confused2:
I would like to get about 400-500lbs of suitcase weights so I can use it without the FEL. It aint so bad in open fields, but in/around tight stuff, the FEL hampers mobility and manuverability
   / Bushhog 306 fresh painting #22
looks like new now anyway
   / Bushhog 306 fresh painting #23
wow..ill get some pics of mine..its in waaaaaaaaaaaaaay worse whape than yours was..but i traded a 150# fert spreader for it....and 100 bucks.
mine has no sides on either side..but i think ill be putting them on. enclosing all of it. im sure it was to let the debris out but i need the good mulching of the enclosures.
mine was in pretty bad shape. but if the gearbox is good, the rest is easy if you are capable. They are very good heavy duty cutters and certainly worth saving
   / Bushhog 306 fresh painting #25
i coouldnt buy a 6 ft hvy duty unit for the 250 ill have in it...and i sold my hammered 5 ftr already for 300...soon enough itll be making me money! woohoo
2007 Amkus Rescue System (A50322)
2007 Amkus Rescue...
2025 Safety Basket Forklift Attachment (A50322)
2025 Safety Basket...
2015 CATERPILLAR D6T LGP CRAWLER DOZER (A51242)
2015 CATERPILLAR...
2022 Bobcat T770 Compact Track Loader Skid Steer (A49461)
2022 Bobcat T770...
2019 CATERPILLAR 308 CR EXCAVATOR (A51242)
2019 CATERPILLAR...
FULL ACCESS TOOL BOX (A50854)
FULL ACCESS TOOL...
