I checked the pan, and found some debris packed under one of the blade bars. The same amount of threads are showing where the blades pivot and there is a small amount of play (up and down) on the blades. It appears normal, allowing the blades to swing freely.
The cutter ran smooth, and I thought I had the problem solved. But, a couple hours into it, I shut down the PTO to move something, started it back up, and the vibration was back. Shut it down again, and re-engaged slowly before the blades and spun down...and it was smooth again...smoother, anyway.
Perplexing. I never had this trouble with the 6 footer. I may try pulling the driveshaft and rotating it 180 degrees (You can do that..right?).
I also will adjust the slip clutch according to the owners manual...as soon as I get the manual. It was not delivered with the tractor.
