Rotary Cutter Bushog
   / Bushog #1
Smokeydog
Elite Member
Knoxville, Tennessee
Kubota B26, M59, M5030DT
New to me 286 bushog. $1,300. Some improvements over the past 25 years compared to my old one. Hard to find good used equipment. New stuff is getting expensive fast.
Anybody found a good rebuild for the front skids?
My old one didn’t have bolt-on replaceable skids. This one is only 1/4” thick and already worn thru at the front corners. Thinking of bending and welding a 12” long by 3”x0.5 CR flatbar on the front corner skids.
   / Bushog #2
Unit looks in decent shape to have the skids wore out. I would weld new flat stock to rebuild skids and go cut some weeds.
   / Bushog
Not much wear, stored inside. Just set too low in the front. My old one sides are well worn and not as heavy. Everything is well worn. Still cuts good but having one with better sides will help.
   / Bushog #4
Around here - hard to find ANY used equipment. Unless you have 400 to 600 hp tractor.
   / Bushog #5
What type of farming operation"s do they have going on in the state of Washington that require all those 400-600 hp tractors? Just curious.
   / Bushog #6
The big crop - wheat. Mid to southern WA and ID. Known as the Palouse. World famous for wheat production. The Palouse is the most productive wheat growing area in the United States.
   / Bushog #7
10-4 would have never guessed it, that's a long way from Florida. 😁 .
10222 (A56858)
10222 (A56858)
Brandt 1070 Auger (A59814)
Brandt 1070 Auger...
2018 Husqvarna 21in. Push Mower (A59231)
2018 Husqvarna...
2013 Infiniti G37 Coupe (A59231)
2013 Infiniti G37...
1408 (A57192)
1408 (A57192)
2013 Ford E-150 Passenger Van (A59230)
2013 Ford E-150...
