buy 425 or 1430 ?
   / buy 425 or 1430 ? #11
No problem. They really are great, dependable machines. But they are machines and machines do break down sometimes. Glad to be of help in your decision. Keep us posted as to what you decide. /w3tcompact/icons/smile.gif
   / buy 425 or 1430 ?
Hope this doesn't muddy the waters but a lack of "ability, desire or time" to MAINTAIN (change oil,clean debris from radiator,lube bearings,clean air filter,etc.) will probably make for a bad tractor experience,no matter the brand or dealer...
One can get away with no ability,desire or time to REPAIR...
The best research you might do right now could be finding repair guys in the area to handle specific REPAIRS(e.g.,hydraulics,engine,electrical) This can include dealer service facilities,too.
Another philosophical way of expressing all this; For a successful tractor(anybrand) owning experience--One must possess a DESIRE to MAINTAIN it.(not necessarily fix)...
No, I don't want to start a new TBN forum on philosophy...
(I think there already is one)/w3tcompact/icons/grin.gif
   / buy 425 or 1430 ?
Oh, I'm afraid I have mislead you guys with my "maintain" statement. I have no problem with the "maintenance" part of the equation. That's just part of ownership, and the regular maintenance I can handle. The "fixing" part is what scares me.
   / buy 425 or 1430 ? #14
I really feel that you could still go with the PT and have no problem finding someone in your area to complete any repairs needed. As already mentioned, most of the parts are standard and can be found in most repair shops. I had a 30hp White and the closest dealer was 40 minutes away. The local repair shop for small engines had no problem doing what I needed.
PJ
   / buy 425 or 1430 ?
How would I go about searching for a repair shop? What are the questions I should ask when inverviewing repairmen? And, given my minimal skills, would I be better off going with the 25 hp Kohler or the 30 hp diesel?
   / buy 425 or 1430 ? #16
<font color=red>would I be better off going with the 25 hp Kohler or the 30 hp diesel? </font color=red>
I have the 1845, which is bigger, but am constantly impressed with the capability of the 400 series machines. As you go bigger, you get a bit higher lift and a little more power margin to swing bigger mowers, but you trade off a little maneuverability. For your size place, you certainly can use either the 1430 or the 1845. I don't think it's a question of maintenance or repair. The biggest factor is money. The diesels are more expensive and Deutz diesel mechanics aren't everywhere, but you can find them.
The 422 is a tremendous bargain right now, I think. Any repair shop that deals with commercial lawn equipment, Exmark, Gravely, Toro, etc. should be able to work on a 422 or 425. With the 425, almost any lawn equipment shop will have experience with the Kohler.
First, I'd call Power Trac and see if they can identify an owner near you. I was lucky to come across a couple near here that I could talk to, Bubenberg being one.
Then, look in the yellow pages for Robin, Kohler and Deutz engine factory designated repair shops.
For interviews, just ask if they have experience with hydraulic and hydrostatic systems. If they tell you they know everything, keep looking. If they say thay have some experience and probably can figure the systems out, you may have found the right place.
Ask if they've worked on a Power Trac. It's like the old Maytag ads, PT mechanics don't get much work, but you may find someone who has heard of the machine.
Check Dave Sisk's posts. He has an old machine, and found a place to work on it. He hasn't posted results, so maybe his experience wasn't great, but apparently the shop he found was willing to pull the engine from his and work on it without any hesitation.
Part of the fun of a Power Trac is doing this kind of information gathering. The next step is test driving. I hope you can get to Tazewell or to a PT owner and try the machines, along with testing of a lot of conventional tractors. You learn something with each test and conversation - and your money's still in the bank.
   / buy 425 or 1430 ? #17
I agree with you. There is a big difference between changing engine oil filters and changing engines /w3tcompact/icons/laugh.gif
As long as you do the regular maintenance, there probably won't be any need to do major repairs. But thing do happen, because it is a machine. I've been very lucky to ahve machines that ran for 20 or more years with nothing but putting gas in them. However, I believe that is the exception, not the rule.
If you have people that can do the major repairs for you, then go for it. If you do not, stick with a brand that has a dealer/service support network like the big three, JD, Kubota and NH.
   / buy 425 or 1430 ? #18
Charlie's comments could not have been more on track. As far as type of engine, my 30HP was a diesel but my new purchase will be a 25 Kohler. My selection is based on long-term needs.
PJ
   / buy 425 or 1430 ?
...Whew....
That was a close one....Thought we lost you there for a moment....
On repair, even if you chose a dealer supported machine...
that respective service dept. is more important than the brand name on the store front.(opinion)/w3tcompact/icons/smile.gif
Toyota 6FGU25 Forklift  5,000 lb Capacity (A53472)
Toyota 6FGU25...
Toro Workman MDX Utility Cart (A51691)
Toro Workman MDX...
Deere 9970 Cotton Picker (A53472)
Deere 9970 Cotton...
2024 Greatbear Forklift Jib (A51573)
2024 Greatbear...
NEW HOLLAND TN75SE TRACTOR (A51247)
NEW HOLLAND TN75SE...
2020 Kubota RTV-X1100CW-A (A47384)
2020 Kubota...
