Tompet
Platinum Member
- Joined
- Oct 6, 2004
- Messages
- 765
- Location
- Ohio
- Tractor
- Ferguson TO 20, Kubota B3300, BH77, Massey Ferguson 1540
I am 32. I split the property with my parents and my Dad is 66. They will be retiring there. I don't mind the cold but he does...so a cab does make sense. Thanks again guys for all your input, I've valued every response.
As an alternative, my friends are all telling me to skip the tractor and just hire the work out. It's cheap labor where I'm at. They said it will be cheaper in the long run and save me time. Tough decisions...
Welcome to the site.
Maintaining that much property, even on a basic level and leaving some areas go wild, you will be calling and coordinating "cheap labor" quite often. It would work, especially for tasks you are unfamiliar with, or don't have the time to accomplish. However, if you like doing some things on your own, you will be thankful for a tractor with an FEL. It allows you to accomplish a task or chore quickly on the spot. I assume your dad is active and would enjoy using a tractor on a property like that in retirement??!!
Anyway, you can find used deals, but it does take time. I found a 40hp Massey 1540 with 270 hrs. and 6' Woods brush hog in very good condition for $11k, but I had another tractor and was not in a big hurry which made a difference in the search.
You received a lot of good advice and opinions on size etc. The more you stop and check out local tractor dealers, you will learn a little each time you stop. It sounds like you are not under any time pressure to search and weigh choices for brand/size/features and new vs used. You'll figure it out!
Here's a like new Massey in your area with q/a on FEL and set of forks (a VERY handy attachment) and only 49 hours. It's just under the 40hp and over size that others have stated that I agree with, but it is a reference point.
Massey Ferguson 1734 Utility Tractor
God luck in your search, and at your age may you have many many years of enjoyment on a beautiful piece of land.
