jeff9366
Super Star Member
- Joined
- Jan 14, 2011
- Messages
- 12,787
- Tractor
- Kubota Tractor Loader L3560 HST+ ~~~~~~~~~~~~~ 3,700 pounds bare tractor, 5,400 pounds operating weight, 37 horsepower
I found myself toying with the idea of a cab. I think an open station may be more suitable for myself as I find I am stepping on and off the machine regularly
An open station tractor will have a somewhat lower center-of-gravity. A cab on a 4,000 bare weight tractor weighs around 700 pounds, all above the rear axle height.
When buying new, consider that tractor cab weight is equal to liquid filled tire weight, with cab weight mostly over the rear wheels. On hills, tractor cab or liquid filled rear tires. Probably not both.
You have not expressed an intention of farming. I tractor only when the weather is nice, in Florida most of the time. In summer when it gets hot, I start tractoring at 6:00 AM and finish for the day by 12:00 Noon.
45-horsepower to 50-horsepower should be adequate on hills and powering your planned implements.
- This is what I assumed, although some of the larger flail mulchers I have been looking require 50hp minimum. I also assumed (possibly wrongly?) that a post rammer may require a bigger sized tractor.
4,000 pound bare weight tractors are usually available with up to 60-horsepower.
FEL lift capacity on 4,000 pound bare weight tractors is usually around 2,000 pounds.
Full pallets of construction material may exceed 2,000 pounds.
In the USA new compact tractors are ordered with HST transmissions about 90% of the time.
Try -REPLY WITH QUOTE- button.
