Buying Finish Mower - 6ft vs. 5ft.
   / Buying Finish Mower - 6ft vs. 5ft.
Danny,
Thanks for the final consideration... Ya no problem..my acreage is for the most part flat. I have one portion that has a slope but have that planted in native grasses and prairie flowers and some trees, somewhat growing wild so am not cutting it and I can go around it for the other portion of my property....PS: I am in Nebraska, so most ground is fairly flat...
Thanks...
   / Buying Finish Mower - 6ft vs. 5ft. #12
Surge,
The only other consideration that I would throw in is "Do you plan to trailer the tractor / mower combination?"
I was in the same boat that you are in and went with a 5 foot mower because I could not find a 6 foot mower that would fit on my 6.5'x16' trailer (I did find one 6 foot rear discharge that was only 1" too wide, though).
Having said all of that, let me add that I just found a pretty good deal on a used 6 foot rear discharge mower. It has two flat tires so I have not been able to really test it yet. I plan to use it most of the time and take the 5 foot mower when I have to go somewhere else with the tractor.
Kelvin
Kelvin,
I don't plan to trailer, at least have no immediate need...
I do have a 5X10 foot trailer, single axle and has a 3500 lb. rated capacity, but it has solid sides. The length of the tractor is (9'10") and the width would prohibit even a 5 ft. deck at this point as I would presume it would acutally be wider that 5 ft. overall width.... My tractor is appx. 54 inches wide, so it is a tight fit to begin with..
I guess if I need to transport it will take two trips.... so hopefully I won't have to go far.... Thanks for the additional thoughts.!!
Kubota BX23 4x4 Backhoe (A51573)
Kubota BX23 4x4...
2016 Dodge Charger Sedan (A51694)
2016 Dodge Charger...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket ONE PER LOT (A52748)
Kubota 24in Quick...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
Super Material Lift MH1000 (A52748)
Super Material...
