BX 1800 rear axle seal leaking
   / BX 1800 rear axle seal leaking #11
Mission accomplished,as stated just had to pry out old seal with a stiff putty knife,remove the ring or clip with snap ring pliers .I did have to bend the pins a little
to get the right angle to access the snap ring. Pulled the axle and bearing out and remover ring holding the bearing on the axle. Tapped the bearing off the axle
it was just a light tap fit, not a heavy press. I did replace the bearing also,just to be safe. All in all not that bad a job. Thanks to all for the advise and suggestions.
Appreciate the follow up, now I know that it won't be so hard if I have to do this. If I'd known this earlier, I could have saved my buddy a couple hundred bucks.
2012 Ford F-550 Crew Cab SWAT Transport Truck (A55852)
2012 Ford F-550...
8 Cubic Yard Dumpster (A55851)
8 Cubic Yard...
2018 New Holland C227 Compact Track Loader (A55315)
2018 New Holland...
2016 Freightliner M2 106 4x4 Altec Bucket Truck (A55852)
2016 Freightliner...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2025 Mower King SSRC72 (A56469)
2025 Mower King...
