BX 2200 Changing Anti-Freeze
   / BX 2200 Changing Anti-Freeze
Things I learned today changing the antifreeze. /forums/images/graemlins/grin.gif
Before you go out and look for antifreeze, make sure you check the manufactures web site for the proper SAE number you need. That information is NOT on the plastic gallon, I had to come back home and check it out, and then go back and buy the antifreeze. /forums/images/graemlins/frown.gif
Its all done, /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif easy to do /forums/images/graemlins/smile.gif /forums/images/graemlins/smile.gif, after flushing with water about 4 times, I got most if not all of the old antifreeze out. Blocking the air intake vent with paper helped get the engine above 180F to open the thermostat.
Thanks for your suggestions, it made the job go quick and easy. /forums/images/graemlins/tongue.gif /forums/images/graemlins/tongue.gif
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
Kubota RTV500 (A47384)
KMC 5610 LOT IDENTIFIER 33 (A53084)
KMC 5610 LOT...
UNUSED HURRICANE F10 10' WROUGHT IRON SITE FENCE (A51248)
UNUSED HURRICANE...
2017 CATERPILLAR D6K2 LGP CRAWLER DOZER (A51246)
2017 CATERPILLAR...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
