BX 2200 Grease Fitting- Foot Peddle
   / BX 2200 Grease Fitting- Foot Peddle #1
NY_Yankees_Fan
Warren County, NJ (60 miles from NYC)
Kubota BX 2200
The grease fitting on the foot peddle will not take grease. I took the fitting off and grease flows through the fitting fine. When I put the grease gun on the fitting I can not pump the handle, regardless of how much pressure I apply. The foot peddle is slow to react and stop the tractor when I take my foot off of it.
Any ideas??
Thanks
Tom
   / BX 2200 Grease Fitting- Foot Peddle #2
Your pedal pivot has probably gotten a bit of moisture into it and has a thin film of rust on it, the bushing clearance was probably so tight that it would not take grease from the get go. I had the same trouble on my BX which was one of the early ones with no grease fitting at all, after installing one myself I found that I still couldn't get grease into it until I removed the pivot and polished the shaft and honed out a little material from the bushing. You will have to remove the floor pan in order to get the pivot off the frame, however if your machine is fairly new I would get the dealer to do the job for you.
PIN PULL AERATOR (A58376)
PIN PULL AERATOR...
Bucket Pallet Forks (A57454)
Bucket Pallet...
45 Gallon Fuel Transfer Tank (A57454)
45 Gallon Fuel...
(1) HD 24ft Free Standing Corral Panel (A57454)
(1) HD 24ft Free...
International 565 Loader Tractor (A59814)
International 565...
SKLP Massage Chair (A57149)
SKLP Massage Chair...
