BX 2230 owners with 60" MMM
   / BX 2230 owners with 60" MMM #1
Scrounger
Platinum Member
Bethlehem (Lower Nazareth) PA
Kubota BX2230
BX 2230 owners with 60\" MMM
I was admiring the Orange Wonder and noticed that when the MMM is fully raised the gap between the tires is not equal. The right side is much closer to the tire than the left side. Is this the same on your BX?
Kubota really cuts it close with the clearance on the tires to the deck.
   / BX 2230 owners with 60" MMM #2
Re: BX 2230 owners with 60\" MMM
My BX is the same way. The dealer told me that there is no way to increase the distance from the tires without missadjusting the deck. I tried every adjustment in the manual before calling the dealer. It's just another one of those BX design issues that you have to learn to live with. My deck even rubs on the tire under certain conditions. I have bar tires, so that makes the situation worse.
John
SO yours is closer on the right than the left too then? I have the bars also and basically can scrape mud off then.
   / BX 2230 owners with 60" MMM #4
Correct, the deck is closer to the tire on the right side. Another issue that I have with the deck design is that you cannot rotate the left rear antiscalp roller 90 degrees (without forcing it past the tire) to remove the deck. Either the deck needs to be 1 inch narrower or the wheelbase needs to be 1 inch longer. I suspect the 60 inch deck was designed for a bigger tractor and they "made it fit" the BX line.
I am VERY pleased with the quality of cut that I get.
John
   / BX 2230 owners with 60" MMM #5
None of these issues with my 54" deck. Sorry. /forums/images/graemlins/crazy.gif
Sorta wish I had the 54" too but when I went to pick up the 54" the dealer gave me the 60" since they didn't have a 54" in stock.
   / BX 2230 owners with 60" MMM #7
I would say that you got the better end of the deal then. My 60"MMM is the same way. But I still get 6" more per pass. Guess I'll live with it. I mean there are lots of imperfections with the better half and I still keep her around.
   / BX 2230 owners with 60" MMM #8
Mine are even. Are you sure one of your L shaped pins that secure the rear of the mmm is not out of its socket?
   / BX 2230 owners with 60" MMM #9
JWE,
I just lower the deck a little and it misses. You might want to give that a try.
Scrounger,
I haven't gone out to look at mine, but I think my left side is closer on the BX1800. I will have to double check that.
   / BX 2230 owners with 60" MMM #10
surfran
I have tried all positions of the deck and even experimented with the combination of rear tire position and deck height. There is one combination that will alow me to rotate the antiscalp with the minimum interference but it is a pain to get it aligned (tire tread position and deck heigth). I usually just force the deck forward with a pry bar until the wheel will rotate. If I have the FEL on, I lift the tractor and that helps. The only resolution is to pull the deck forward via the parallel linkage adjustment. But then the front of the mower is higher than the back. That's what the dealers do; and hope that you don't notice that the front-back level is out of adjustmet. /forums/images/graemlins/confused.gif
I stopped at the dealer last week to pick up an oil filter and there was a guy complaining to the service manager about the same problem.
On the positive side, if you have the deck aligned to spec and have the tires inflated to the correct pressure you will get an excellent cut. Even on hilly property with lots of anlguations like I have. /forums/images/graemlins/smile.gif
John
2005 CATERPILLAR 321C LCR EXCAVATOR (A51246)
2005 CATERPILLAR...
2025 CFG 48in Forks and Frame Skid Steer Attachment (A50325)
2025 CFG 48in...
FAE UML/SSL 150 VT QUICK ATTACH HYD MULCHING HEAD (A51406)
FAE UML/SSL 150 VT...
3 POINT  7FT RAKE (A52472)
3 POINT 7FT RAKE...
2006 MACK CV713 KILL TRUCK (A52472)
2006 MACK CV713...
41Boxed VariDesk Pro Plus 36 Standing Desk Converter (A50325)
41Boxed VariDesk...
