Bx 2230 Post hole digger
   / Bx 2230 Post hole digger #11
Barryh said:
The (L7200-JR) is specifically designed for a Sub Compact tractor.
Concur. When Mr. AceDeuce originally purchased the PHD, he paid for a JR and got the full-on model. It fit, so he just went with it. Or as the story goes.
I think the JR is the more appropriate model and you can't go wrong by getting it.
You'll probably still need to deal with a draggy tip, though. Nothing a strap won't fix.
   / Bx 2230 Post hole digger #12
I just got the 7200jr. It is a pretty stout unit, and I don't see the need for extra boom lift or wider "U" bracket.
I know this doesn't help with the BX, but here it is pictured on a 20hp Yanmar.
   / Bx 2230 Post hole digger #13
This may be a bit off topic but how do the post hole diggers do in rocky areas? Here in NH the rocks grow right out of the ground...I don't think I could dig 6" down before hitting a decent sized rock.
Just wondering how many bits get busted or worse....
   / Bx 2230 Post hole digger #14
I know the JR has the yellow U bracket as pictured on Tony123's machine. I was worried that my Kubota sales rep might make the same mistake and, order the full size.
I must have asked him 4 times to make sure it he ordered the JR. I believe yours has the black U bracket?? Nice to know it would fit anyway. :eek:
   / Bx 2230 Post hole digger #15
That does look like a hefty unit, nice looking Yanmar also. How hard is it to change out the post hole digger? Do you keep it on a skid or rack of some sort when it's off of the machine. I plan to build some shelves or racks of some sort for out in my shed as I acquire more attachments. My garage is crowded enough with tools. Thanks for the picture. :eek:
   / Bx 2230 Post hole digger #16
Guess I'm gonna find out, my ground is pretty rocky along with clay and shale. I'm sure Keith, Ace or Tony can chime in on that. I figure I better go get at least 12 shear pins to start with.
I also read on here these post hole diggers like to get stuck between roots and rock. Sometimes the only way to get them back out is to use a pipe wrench give it a turn or two in the opposite direction. Worst case dig them out by hand. Not looking forward to doing any digging, done enough of that. :confused:
   / Bx 2230 Post hole digger #17
Pengo is the place to look when you need to start drilling into rock:
http://www.pengoattachments.com/
   / Bx 2230 Post hole digger #18
Pengo
Those look nice...bet they are spendy...
I hope in the next couple of years to put a pole barn and I will need to either rent or buy a PHD. My neighbor used a gas driven one it seemed to work for him. So maybe I'll be ok...
   / Bx 2230 Post hole digger #19
Pengo
Thanks for the link Tom, I have it bookmarked. ;)
HYDRAULIC PUMP FOR JOHN DEERE 544 WHEEL LOADER (A51244)
HYDRAULIC PUMP FOR...
2020 KUBOTA RTV...
SKID STEER QUICK ATTACH PALLET FORKS W/ 48" FORKS (A51244)
SKID STEER QUICK...
10 x 31 Mayrath Truck Auger (A50515)
10 x 31 Mayrath...
JCT SKID STEER QUICK ATTACH AUGER SET (A51243)
JCT SKID STEER...
International 140 Tractor (RUNS) (A50774)
International 140...
