bx-23 IN GARAGE oil type,and quantity question
   / bx-23 IN GARAGE oil type,and quantity question #1
escavader
Veteran Member
western maine
bx-23 ,
HEY FOLKS
Doin my 50 hour maintanance,got a couple problems
first,the dealer sold me 15-40 kubota oil,it didnt call for that in my book,i already dumped it in,havent started it though....ok or not?
second,they sold me a 2.5 gallon jug of super udt.the book calls for 2.7....i need more dont i?will it be ok to just move it out of my garage,until i can get there?
I WONT START,OR MOVE THE TRACTOR TIL YOU FOLKS GIVE ME THE THUMBS UP.I guess i shouldnt have assumed they were gonna give me the right stuff.
ESCAVADER
   / bx-23 IN GARAGE oil type,and quantity question #2
Re: bx-23 IN GARAGE oil type,and quantity question
Alan, Kubota has been a little slow in updating their manuals for motor oil specifications. 15W-40 is the most common motor oil used in diesels. I assume it's also CH-4 or later API rating. So check the oil level with the dipstick and if it's full of 15W-40, you're good to go. As for the Super UDT, it's not unusual to either fail to get all the old hydraulic oil drained out, or for a tractor to hold a little different amount than the manual calls for. Again, I'd simply check the fluid level, but .2 of a gallon isn't low enough to have to worry about. Sounds to me like that tractor's about ready to use. /forums/images/graemlins/wink.gif
   / bx-23 IN GARAGE oil type,and quantity question #3
The 15-40 is fine I use it all the time. I found I need about 3 gallons of UDT. But it won't hurt it to run it a quart or so low.
Thanks guys,everything looks ok,a little low on the tranny dipstick,probably lower when the filter fills up.gonna run it a little in the garage,and move it into the barn.ill pick up another quart,before i actually use the tractor.thanks for the quick reply.i got two other oil changes,and some rear wheel bearings in a car to do tonite,need the garage back.UP at 4.30 to my sawmill job,where i can get some rest..ha ha
ESCAVADER
   / bx-23 IN GARAGE oil type,and quantity question #5
AS usuall BIRD beat me to the punch /forums/images/graemlins/grin.gif and as usual you can just re-read his post . for he speaks the truth,
   / bx-23 IN GARAGE oil type,and quantity question #6
I used about 4 gal + or - when I did my 50 hour last year. I did use it to change the front axle lube also.
1998 12ft T/A Park Dump Trailer (A52377)
1998 12ft T/A Park...
Peterbilt 377 Semi-Truck (A55218)
Peterbilt 377...
2014 Ford F-150 Pickup Truck, VIN # 1FTFX1ET4EKG11918 (A54865)
2014 Ford F-150...
2011 Kenworth T300 Jerr-Dan 21WSRB Rollback Truck (A52377)
2011 Kenworth T300...
2021 CATERPILLAR D4 LGP CRAWLER DOZER (A51246)
2021 CATERPILLAR...
2011 Ford E-350 Passenger Van (A55788)
2011 Ford E-350...
