bx-23 IN GARAGE oil type,and quantity question
   / bx-23 IN GARAGE oil type,and quantity question #1
escavader
western maine
bx-23 ,
HEY FOLKS
Doin my 50 hour maintanance,got a couple problems
first,the dealer sold me 15-40 kubota oil,it didnt call for that in my book,i already dumped it in,havent started it though....ok or not?
second,they sold me a 2.5 gallon jug of super udt.the book calls for 2.7....i need more dont i?will it be ok to just move it out of my garage,until i can get there?
I WONT START,OR MOVE THE TRACTOR TIL YOU FOLKS GIVE ME THE THUMBS UP.I guess i shouldnt have assumed they were gonna give me the right stuff.
ESCAVADER
   / bx-23 IN GARAGE oil type,and quantity question #2
Re: bx-23 IN GARAGE oil type,and quantity question
Alan, Kubota has been a little slow in updating their manuals for motor oil specifications. 15W-40 is the most common motor oil used in diesels. I assume it's also CH-4 or later API rating. So check the oil level with the dipstick and if it's full of 15W-40, you're good to go. As for the Super UDT, it's not unusual to either fail to get all the old hydraulic oil drained out, or for a tractor to hold a little different amount than the manual calls for. Again, I'd simply check the fluid level, but .2 of a gallon isn't low enough to have to worry about. Sounds to me like that tractor's about ready to use. /forums/images/graemlins/wink.gif
   / bx-23 IN GARAGE oil type,and quantity question #3
The 15-40 is fine I use it all the time. I found I need about 3 gallons of UDT. But it won't hurt it to run it a quart or so low.
Thanks guys,everything looks ok,a little low on the tranny dipstick,probably lower when the filter fills up.gonna run it a little in the garage,and move it into the barn.ill pick up another quart,before i actually use the tractor.thanks for the quick reply.i got two other oil changes,and some rear wheel bearings in a car to do tonite,need the garage back.UP at 4.30 to my sawmill job,where i can get some rest..ha ha
ESCAVADER
   / bx-23 IN GARAGE oil type,and quantity question #5
AS usuall BIRD beat me to the punch /forums/images/graemlins/grin.gif and as usual you can just re-read his post . for he speaks the truth,
   / bx-23 IN GARAGE oil type,and quantity question #6
I used about 4 gal + or - when I did my 50 hour last year. I did use it to change the front axle lube also.
2021 FREIGHTLINER CASCADIA SLEEPER TRUCK (A54313)
2021 FREIGHTLINER...
JOHN DEERE 7300 LOT NUMBER 18 (A53084)
JOHN DEERE 7300...
2019 HINO 195 LCF BOX TRUCK (A54607)
2019 HINO 195 LCF...
2011 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2011 Ford F-150...
2016 Ford Focus Sedan (A53424)
2016 Ford Focus...
Utility Trailer (A52377)
Utility Trailer...
