BX 23 Relief Valve location
   / BX 23 Relief Valve location #1
srossman
Elverson PA
Kubota BX-23
Ok, so I've been following another thread in increasing the relief valve pressure on my BX 23 and I've tested it and found that my pressure is down a bit. I've searched and searched for the location to put in a few shims to increase the pressure and I can't find it. Can anyone give a very detailed location or have a picture of where to adjust the pressure on my BX 23.
Thanks,
Scot
   / BX 23 Relief Valve location #2
Here is a couple of pages if I can get them attached
tom
  • bx23releifpdf.pdf
Thanks Tommmu, That is exactly what I was looking for. Now if it will just warm up a little bit, I can get out there work on the tractor. 27 degrees is a little to cold to be fiddling with this stuff outside. :)
   / BX 23 Relief Valve location #4
Yea I need it to warm up too I "tried" to get to my cabin last weekend and slid off the road on the ice and did over $6000.00 in damage to it.
come on spring!
tom
   / BX 23 Relief Valve location #5
My BX23 has a bit over 300 hours now, and seems to have lost some of it's grunt. I am collecting the pieces to test the releif pressure myself. The location information is great, but what is the correct releif pressure for this tractor?
   / BX 23 Relief Valve location #6
Be careful what you wish for. I boosted my BX24 and yes it has more power but it will make it more noisy and it appears my abrupt stop in reverse got way worse.
I think the correct pressure is somewhere around 1850 PSI. I boosted mine to about 1900 -1950 when it was all done. The documents that Tommu provided were dead on. Once I had them in hand it was a couple of hours and the job was done.
   / BX 23 Relief Valve location #8
Wow- that is important info need to know! The reverse can get worse with bumped up power.:eek: . Now I gotta figure if this is worth it or should I get into swapping out shims as needed? If all I am doing is mowing, what happens if I lower the power from the way it is now, will the reverse become softer ?
   / BX 23 Relief Valve location #9
The two circuits are not related other than the same fluid is used.
Shimming the system rellief will have no bearing at all on the hydro - must be one of those perceived differences.
The hydro reaction is due to no dampening of the hydro linkage as was found on earlier machines.
   / BX 23 Relief Valve location #10
I don't think the reverse and the pressure boost on the hydraulic is is related.
They have same fluid and sump but different pumps and circuits completely.
tom
I guess Yankee Clipper is a faster typer than I am.
1993 INTERNATIONAL 9700 TANDEM AXLE CAB OVER (A45676)
1993 INTERNATIONAL...
Genie 5519 Telehandler (A45336)
Genie 5519...
Case IH 455 Round Baler (A46884)
Case IH 455 Round...
Hoof Trimming Table (A47809)
Hoof Trimming...
Bobcat S650 Skid Steer (A47809)
Bobcat S650 Skid...
Safety Shower (A45336)
