BX 2350 Oil Question
   / BX 2350 Oil Question #1
Kubota 2350
Platinum Member
Michigan, In The Thumb
2016 JD 3046R Cab ...................... Mower: 2016 Scag Tiger Cat II ZTM
Anyone use Rottla T-6 in their small Kubota tractors?
I always used the Kubota oil in this tractor when I owned it, I sold it to a friend and he want's to use the synthetic Rottla T-6, anyone see any problems with this?
   / BX 2350 Oil Question #2
I use it in my bx1860.
I don't see a problem switching. In the early years of synthetic they said you would cause leaks if you switched from conventional. Now I don't think it matters as much.
   / BX 2350 Oil Question #3
I've used it for ten years in my tractor and motorcycles...
   / BX 2350 Oil Question #4
Once I hit 50 hours I change to Amsoil. I have found that the engine is much quieter in the winter with the synthetic. Just my 2 cents worth.
   / BX 2350 Oil Question #5
I use it in my BX25. No issues.
   / BX 2350 Oil Question #6
I use T6 also, almost 800 hours. No problems
   / BX 2350 Oil Question #7
I switched to T6 a few years ago and noticed immediately that it was smoother/quieter, especially at low rpm.
   / BX 2350 Oil Question #8
I have a BX2360 and am getting ready for my first oil change. Is Rotella T6 SAE 5W-40 OK to use for this change. I live in Massachusetts and my tractor is garaged ?
   / BX 2350 Oil Question #9
Not a oil expert. In general make sure it has the right specs such as
(Below 32°F use SAE10W or SAE10W-30 or 10W-40) (32°F to 77°F use SAE20 or 10W-30 OR 10W-40) (77°F and above use SAE30 or 10W-30 OR 10W-40)
To get real detail and perhaps more important the specs in your manual may be similar to
(API Service Category: CJ-4, CI-4 Plus, CI-4, CH-4, CF-4, CF, CE, CD, CC/SL, SJ)
As far as Google goes the numbers and info above are correct for your unit. Just find the specs for your unit year made to make sure. Rotella brand has a great reputation.
   / BX 2350 Oil Question #10
Yes it OK for your tractor!
Actually better than you really need.
Factory fill is 10W30 conventional oil.
Kubota or Shell Rotella 10W30 would be perfectly adequate for your garage-kept tractor at a lower cost.
But,since we love our tractors,why not use the good stuff?
Good Luck!
2014 BMW X3 AWD SUV (A50324)
2014 BMW X3 AWD...
2012 Ford F-450 Altec AT200A 30ft Bucket Truck (A50323)
2012 Ford F-450...
2016 WITZCO RG-35 RGN LOWBOY TRAILER (A50459)
2016 WITZCO RG-35...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
John Deere 1775 NT Exact Emerge 24 Row Corn Planter (A52349)
John Deere 1775 NT...
KJ 10' Galvalume Corrugated Steel Panals (A50121)
KJ 10' Galvalume...
