Tires BX 24/25 - loaded tires?
   / BX 24/25 - loaded tires? #1
Eightpoint
Virginia
Kubota BX2230
Am looking into getting either of these machines and have received conflicting reports from different dealers on whether the rear tires should be filled or not.
So what is the group consensus here - empty or filled?
   / BX 24/25 - loaded tires? #2
I opted for foam filled rears mainly to be flat proof. More than one weekend of seat time was ruined by a flat rear tire.
As a side benefit, I also noticed i have a lot more stability on hills and the backhoe doesn't move the tractor around like it used too.
The only negatives I've heard come into play if you use the TLB primarily for mowing.
   / BX 24/25 - loaded tires? #3
I had my BX24 for 2 years without them loaded. I just loaded the tires with rimguard just recently and boy -let me tell you - what a difference!! I think small, tippy kubotas should be mandatory loaded unless customer request not to have it loaded. If I got a BX without BH, then it would be 50/50 with loaded or not depending on tasks at hand. If it just mowing 90% of time then no i wouldnt get it loaded unless you mow slopes alot. what ar eyou planning on doing with yours?
   / BX 24/25 - loaded tires? #4
Loaded...makes BX more stable in all situations, especially with BH off and FEL on. Only downside for me is early spring/late fall mowing and leaf pickup...ground wetness is more of an issue.
As for dealer opinion...with no discussion, mine came loaded.
   / BX 24/25 - loaded tires? #5
The owners manual for the BX24 says they should not be loaded when the backhoe is mounted. Mine are not loaded primarily to avoid lawn damage.
   / BX 24/25 - loaded tires? #6
When I bought my BX24 a few months ago my dealer gave me the impression that they rarely if ever sold the BX without loading the rears. I have been very happy with mine so far, minimal lawn damage too.
Matt.
   / BX 24/25 - loaded tires? #7
My dealer really didn't give me a choice for my BX24. He said they fill all BX24's with rimguard and I didn't question it. I'm glad they are filled after all of the work I have put my tractor through.
   / BX 24/25 - loaded tires? #8
We recommend loading the rear tires on all Compact tractors with front end loaders. Much safer tractor with loaded tires. You can also get rear wheel weights if you wanted something that can be removed.
Emerich Sales & Service inc.
   / BX 24/25 - loaded tires? #9
As a sales person looking for the best value for the customer on ballast I recommend the cast weights. You only buy them once! If there is a need for more for the type work you are doing, then go to the liquid weight. For many tire designs the liquid hinders traction so it's not the best system for adding the ballast but it is the least expensive initially.
To have a little pucker factor once in a while will make for a better operator, just like testing your car out in the snow if you have it by putting it into a skid on ice to test the tires.
To heavy, and you pay every day to move it!
It only takes one flat tire and you have to buy the liquid again!!!!
(APPROX 23) 2" X 2" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 23) 2" X...
2022 Bobcat T66 (A53317)
2022 Bobcat T66...
2015 Volvo VNL 64T (A55315)
2015 Volvo VNL 64T...
2013 Chevrolet Express 3500 Passenger Van (A55973)
2013 Chevrolet...
MURRAY PUSH MOWER (A55745)
MURRAY PUSH MOWER...
2018 Caterpillar 259D Compact Track Loader Skid Steer (A55973)
2018 Caterpillar...
